Question about JVC Everio GZ-HD7 Camcorder
Camcorder water damaged.
My camcorder was damaged on a weekend shoot at a beach. To make a short story shorter. The camera WAS NOT submerged in water, but water splashed the lense which didn't have a protective housing. I dried all the water on the outside with a towel & used a blow dryer to penetrate the cracks on the inside. Still dead results. The next morning I notice a white residue from the salt water.
Being that I was'nt paid for the video shoot, my pockets are weak because there was nothing to review.
I thought of only 3 options to my problem:
(a) Consider it trash & purchase another
(b) Check a repair shop
(c) Rent A Camera
What's a reasonable solution?
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
My son put my camcorder in the washing machine. It's a Sony digital HD. I took it out before it started the spin cycle but it had been submergered in water. There is water sitting in the lens. Can it...
I do not want to be funny here but I would have let it spin. The water is damaging to the lens and would cost you more money to repair then the camera's net worth.
Many people tried the RICE method where you put the unit under a huge bed of rice so the moister will be absorbed out of the unit, but you need to take the camera apart to do this and 9 times out of 10 its a waste of time and rice.
Just the lens being submerged would have damage from corrosion.
Good luck
Jul 10, 2011 | Cameras
The description said it was an underwater camera but once i took it underwater it turned off and will not turn on.
Welcome to FixYa.
Before using the camera in under water, you have to secure that battery cover,card slot cover snd DC IN terminal cover are completely closed to prvent water from getting inside the camera and damaging it. Please note that the camera accessories are not waterproof.
Yes, Sanyo VPC-WH1 High Definition Camcorder is a waterproof camcorder, however you can not used it in all types of water. Below are the Cautions concerning use in water.
* The waterproof properties of the camera apply to fresh water and saltwater only. They do not apply to cleaning substances, chemicals or water from spas.
* Do not immerse in water at a depth greater that 3.0m (9.84ft)
* Do not subject the camera to high-pressure water.
* Do not immerse in water for longer than 60 minutes.
After 60 min. of use in water, allow it to dry for at least 10 min.
* Do not immerse in water that is warmer than 40 degree C.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover with wet hands.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover on the beach or at the poolside.
* Do not jolt the camera while it is immersed in water. doing so may cause the battery cover, card slot cover or DC IN terminal cover to open.
And one more thing that you have to do is to chaged/replaced the waterproof seals every year with new ones. For replacing the seals, please consult your dealer and take note that there is a fee for replacing the waterproof seals.
I hope this information will give you an idea on how to use your camera under water.
Feel free to send us your comments and suggestions.
Thank you for using FixYa.
Apr 06, 2011 | Sanyo VPC-WH1 High Definition Camcorder
Handycam submerge for 24 hours in water?was it totally damaged?
My advice is as follows:
Ii the handycam was submerged without the battery on it the electronics may still be fine. you need to take it to the repairman who will open up all the circuit boards and dry them.
If there was a tape i the camera , the tape is damaged and cannot be used again.
The camera mechanism may also be damaged by the water through corrosion , so its absolutely important that you take it to the repairmen for drying as soon as possible.
However if the handycam was submerged with the battery on, then the electronic circuit boards are most likely damaged.
in this case you may weigh the costs of having the circuit boards replaced against buying a new camcorder altogether.
Oct 18, 2009 | JVC Everio GZ-MG130 Camcorder
Water in /on my evrio too it charges but its actin cockamame
BEACH? Salt Water? OOOOH Nooo.
bye bye camera, remove the bateries asap needs to be taken apart soon very soon corrosion loves coper and salt water a good conductor...
Jul 26, 2009 | JVC Everio GZ-MG130 Camcorder
Dropped Sony Camcorder in sea water
This isn't a solution specific to your problem, but maybe similar enough to help. I've dropped both my cell phone and iPod in the water. My friend told me to fill a bowl with uncooked rice and submerge the cell phone in the rice to draw out the water - took about 2 days and all was working fine - same with the iPod, but it took longer (about a week.) You might want to gently clean the battery connections with a Q-tip if you're seeing residue. Good luck!
Jul 25, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Video Flip-flops when shooting outdoor/Focused Bright Area OR Light
Hi Ramki
Camcorder can not be drop, maybe the brain damage and give the wrong figures to the camcorder and caused shot off and on.
I feel sorry about this bad situation, maybe if you have menu, see the trouble shoot, but I doubt it.
Frank
May 21, 2008 | JVC GR-D22U Camcorder
I'm looking for internal spares for jvc GR D290 camcorder
No spare and no repair now you have opened it. Water damage is likely to have done more than you describe any way.
Aug 05, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Blurry screen
If you got sand/water in unit, it may damaged the circuits. You may have it cleaned completely, which could cost as much as a new camera.
Sep 12, 2006 | Sony Handycam CCD-TRV68 Camcorder
TRouble shooting help needed for the error E:60:10
Non distilled water is conductive. Salty sea water is the worst. The fact that it's conductive means that it's short circuiting the camera when still wet, and if you had the camera on at the time or before it dried then you're likely to have fried it to some extent. apart from that, the longer it has been since it got wet, before you opened it up and serviced it, the more damage you allowed to set in. Corrusion from the salty water is eating away at the electrical boards, and before long the damage is irepairable. You should take it to a lab ASAP when something like this happens and hope they can save it. If the camera got only slightly splashed then there's a chance the damage is only local and can more easily be fixed. Sorry, and I hope you get away with it ;]
Jun 06, 2006 | Sony Handycam DCR-DVD201 DVD Camcorder
JVC Everio GZ-HD7 Camcorder Logo
581 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
