Question about Kenmore Refrigerators
Icemaker not working
Lower level freezer has icemaker; it is not working. we changed the water filter to increase water pressure but still no go; any suggestions?
  • dr_zoland Jun 01, 2009
    my wife recently changed the settings; i think this may be the problem!!!!! you rock local wonder guru! thank you. icelessness
  • 6,784 Answers
Ok, check the temperature to make sure it is on the factory settings. if the temp is set below the factory settings, this will freeze the assembly, in return, not allowing the ice maker to initiate the ice makign procedure properly. if the temp is set to factory settings and the water lines and assembly isnt frozen, thsi will confirm a fualt within the inlet water valve assembly. you will need to replace the water valve assemb ly in this case.
Posted on Jun 01, 2009
    Sergeant:
    Champion:
  • 208 Answers
Turn the freezer off let it reach room temprature there may be ice blocking it from freezing the water :)
Posted on Jun 21, 2009
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Adjust amount of water to ice maker
there is a small setting on the icemaker module, but it only makes a VERY small difference. you would want to fix the water supply issue though. the icemaker fills a ceartain amount of time, not to a level, so if you increase the time, it is still filling so slow that it won't make a big difference.
3 possibillities for slow water flow
1. flow coming into the fridge is too low- plumbing issue, likely at the water valve under your sink.
2. Water filter needs to be changed every year
3. Bad solenoid valve in the fridge. it is where the water enters the fridge.
May 19, 2012 | Kenmore Refrigerators
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and now will not work automatically. It will work...
Good day!!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Hope this information will be helpful..
Thanks for using fixya...
Aug 29, 2011 | GE Refrigerators
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
My icemaker is malfunctioning. I put a water filter in and purged the system but it is now leaking water from the icemaker. I found it iced up so I removed the ice and turned the icemaker off. What do I do...
run it a few more times to get the air out and to give it time to level out when you replace a water filter the pressure is increased and air will stay in the lines until it purges completly and settles down
Aug 23, 2009 | Whirlpool GX5FHDXT French Door...
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Water leaking from freezer compartment and ice maker not working properly
  • the water(in the bottom of the freezer) is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • and
  • the icemaker problem
  • it could be that the water valve is slowly leaking water into up to the icemaker and freezing before dripping out of the tube. then when the icemaker turns on the water to the icemaker it is partially blocked by the ice and sprays water all over instead of gently falling into the icemaker.
  • if this is the case then changing the water valve on the back of the machine and defrosting the fill tube behind the icemaker should fix this problem.
May 27, 2008 | Maytag MSD2456G Side by Side Refrigerator
HOW TO ADJUST WATER LEVEL IN ICE MAKING TRAY
Your water pressure is too low. If you live in an area with low water pressure you would have to get a booster pump for you frig. Otherwise you can check the supply line and make sure it has no kinks in it. according to the manufacturer the small ice cubes will not effect the performance of your frig
Jan 24, 2008 | Refrigerators
Icemaker does not work on subzero 650
My ice maker on the Subzero 650 is up and running again. After checkig the tray and shutoff mechanism thoroughly I checked the display in the fridge aea and noticed a "service icemaker" indicator. I turned the icemaker off and then on again with no change. I then turned the power to the entire refridgerator/freezer unit off, waited ten seconds, and thurned it back on. This apparently must have reset some type of logic because the icemaker immediately began to cycle (ice ejector began to turn slowly) and then I heard the water soelenoid turn on to inject water into the ice trough. It's been 24 hours now and the icemaker tray is filling up nicely. I guess my icemaker just need to be rebooted. The miracles of modern technology. I appreciate the suggestions posted in response to my posting as well as the postings of others with similar issues as well as te corresponding suggestions. All of these together lead me to investigating areas that ultimately lead to resolution. I probably would have called for an expensive repairman if not for this forum. THANKYOU!
Dec 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
83 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
