Question about Kenmore Washing Machines
Kenmore 80 series front loading washer
The water will not stop filling up during the wash and rinse cycle.
  • 15,935 Answers
The pressure switch is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
May 31, 2009 | Kenmore Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
