Question about LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover
LG Env2 randomly turns off
My fully charged env2 will randomly turn off and I will pull it out of my pocket to check the time etc. and realize it has been off for who knows how long. I have the 2-key lock on, so I don't believe that is the problem, have had no random dials etc. Yep, I have the same exact problem! Often, when I close my enV 2, it turns black, not even with the whole verizon shut down with the sound. It's extremely frustrating because I don't even know it's happened till I look at it to find it is off. Anyone got a solution?!
I had the same problem, I took it back to the Verizon store and told it was caused by heat exposure from being outside. He reset my phone and the problem stopped (until I had it outside at the pool again)
Posted on Jun 23, 2009
    Problem Solver:
  • 7 Answers
I have a friend who has the same problem and i think it is because he has over 300 pictures on his phone. if you have alot of pictures try deleting some.
Posted on Jun 19, 2009
I have the same problem and if i squeeze it, it will turn off. Sometimes a simple text will be enough to torque it the wrong way and it'll shut off instantly! I think the battery's loose although it seems pretty snug, I'll probably have to get it replaced.
Posted on Apr 06, 2010
LG enV2 Battery not chairging
It might be your charger or your charger port.
First check the charger by using another charger to test if it will charge.
If not charging that means your charging port is faulty needs to be changed.
Jan 21, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Cannot charge LG EnV2 VX91000 phone
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Jun 30, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
EnV2 shutting off when closed
I have the same problem, only randomly, even with two key lock on. I read on here where someone said he discovered that pressing on the battery real hard (as if in your pocket) shuts the phone down. I tried and it did. I cleaned the terminals (don't scratch them--use Q-tip DAMPENED in 91% alcohol, or rub with soft cloth--don't get white paper circle with xxx wet!). Afterward, I could no longer shutdown phone by pressing battery. Solved? Time will tell. You can also go back to Verizon and they will swap it for a certified used one within the first year.
Jun 29, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
LG enV2 blank internal and external LCD's
yes you need to take the phone to a mobile service center and hvae them replaced the lcd and flexcable.
Jun 06, 2009 | LG enV VX9900 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Hi all...
This was happening to me with my env2 but a friend helped me fix the problem, which is caused by bad contact between the battery and the phone.
Remove the battery from the back.
At the bottom of the recess in which the battery sits are the 4 gold contacts.
First, clean these contacts with a pencil eraser and be sure to clear any eraser leavings fromt he recess.
At the top end of the recess (opposite the gold contacts) you'll see the holes where the posts from the battery pack insert.
For this next part, you'll need a business card or some paper. I've found that a double-layer (single fold) of business card works, so probably a triple or quadruple-layer of paper will do as well. Cut the card such that it is just short enough to fit lengthwise between the post-holes, and wide enough that when folded lengthwise it will fit into the recess. Position the folded piece against the top "wall" of the recess between the post-holes and then insert your battery.
The card/paper pushes the battery downward just enough to make solid connection with the gold contacts. I did this about a month ago, and the phone has never sinced turned off on its own (it was doing it a few times a day prior to that).
KDS63
Apr 05, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover Logo
974 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
