Question about Acer Aspire 5315 Notebook
Whats a good way to cool off a 800MHz CPU in Acer5315 Notebook?
For instance, if I upgrade my 533MHz to a 800MHz would it make a big difference in the temperature if it is Dual-Core or Single-Core? If its going to be hot either way, is there a way to adjust the fan speed or cool it off another way?
  • lleota295 May 11, 2010
    can I hook up a 2 wire Router with a Motorola SB5101 modem from cox cable to have wireless internet?
  • Acer Master
  • 2,404 Answers
It might heat up a little bit more with the change in CPU. Keep in mind the motherboard can only handle so much heat before shutting off. In the BIOS if you could adjust it then it would be only to raise it higher but that means it still would get hotter anyway or if you go lower then the laptop would shut off on you quicker.
I would recommend this courtesy of Xoxide:
http://www.xoxide.com/noco.html
I found this doing a google search for laptop cooler. You can do your own search and look at other sites to get even more ideas.
This is good cause it keeps the laptops really cool and also cause they stay cool, less chance of components on the motherboard going bad and also less chance of hardware going bad as well.
Hope this info helps.
Ben
Posted on May 31, 2009
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
May 13, 2014 | Computers & Internet
Hello there . I have the foxconn 661FX7MI-S motherboard. I wan to upgrade the celeron cpu. What is the fastest processor that is worth putting in it. Also will I be able to use the same fan or will I need...
This is the spec for your motherboard microprocessor......
Microprocessor
Supports Intel® Prescott-T processor in an LGA775 package
Supports FSB at 533MHz/800MHz
Supports Hyper-Threading technology
Feb 10, 2011 | Foxconn 661FX7MF-S Motherboard
I have a Hp wx6000 workstation and would to upgrade it.
According to the HP.com website, that board can support up to 3.2ghz with 533mhz max bus speed:
Intel Xeon processor 2.4 GHz, 2.66 GHz, 2.8 GHz, 3.06 GHz and 3.2 GHz (533 MHz front side bus)
Mar 23, 2010 | HP Computers & Internet
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
CPU compatability
It is not compatible. If your fsb is 533mhz then any replacement cpu would need to be a 533mhz fsb chip. This is unless your motherboard supports different fsb's. You will need to check your manual or the manufacturers website to see what cpu's your system supports. Hope this helps.
Jun 01, 2009 | Acer Aspire 5315 Notebook
Upgrading the CPU
overclocking is adjusting the speed of which a cpu works at (processor = cpu) replacing a cpu is not overclocking and wont cause any problems aslong as the cpu is ment for the motherboard and is supported. depending on the motherboard you may not be able to place in a 800MHZ cpu, but if you find one that fits and works on your model sure go ahead, it wont cause any problems, other than possibly overheating if the cooling is designed for a slower processor.
May 31, 2009 | Acer Aspire 5315 Notebook
Processor motherboard compatibility
Intel® Core™ 2 Duo T8300 (2.4GHz/800Mhz FSB/3MB) it is the Cpu that your mainboard support. no more faster.
May 27, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
Upgrade Ram
No it wont take 800MHz RAM...
Using the DDR2 slots u can have 400MHz sticks (rare stuff), or 533MHz sticks
Using the DDR1 slots u can have 333MHz or 400MHz
Let me know...
Matt
Jan 20, 2009 | EliteGroup 945GZT-M (V1.0) Motherboard
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
