Question about Dryers
Does not spin/tumble
Our 86870100 model Kenmore Clothes Dryer does not spin...It turns on and throws heat, but the tumbler does not tumble...I doubt I am using the right words, but I hope you know what I mean. Please help me out!! How did you 'take it to bits'? Our dryer won't spin the drum anymore and I cannot figure out how to get to the motor compartment without cutting through the side panel on the right.
  • Samuel Charles Spriggs May 11, 2010
    I can't find this model on-line. Are the controls on the top back?
    Is there a seam around the top where it sits on the cabinet?
  • 126 Answers
Sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
Posted on Jun 25, 2009
2 Suggested Answers
juicy_joycie
  • 12 Answers
SOURCE: Does not spin/tumble
IT IS POSSIBLE THAT YOUR DRUM SUPPORT & BEARINGS HAVE GONE, WAS IT SQUEEKING & HAS DRUM DROPPED SLIGHTLY??
IF SO ID SAY THAT IT IS THIS MINE WENT WRONG A FEW MONTHS AGO, SO I TOOK IT TO BITS & IT WAS THE ABOVE PROBLEM, JUST AN IDEA OR YOUR MOTOR HAS PACKED UP, OR YOUR DRUM BELT HAS SNAPPED..
Posted on May 22, 2009
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
My dryer model # 86870100 is running but is not heating up to dry clothes is there a way to fix it
i have the same dryer with the same problem let me know if you find out how to fix it. i think it is the heating element.
Feb 22, 2011 | Kenmore 63942 Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
May 22, 2009 | Dryers
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Dryers Logo
187 people viewed this question
Top Dryers Experts
