Question about Whirlpool GEQ8858H Dryer
DRYER NOT GETTING HOT GEQ8858 - Whirlpool GEQ8858H Dryer
  • 6,784 Answers
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on May 31, 2009
Why is dryer is not getting hot enough
not getting hot or hot enough? if not hot at all it's probably the thermal fuse is blown, if not hot enough you could have a blockage in the blower vent system, which could be from the blower wheel in the dryer to where it vents out of your house. if no blockage then it's probably one of 2 cycling thermostats
Feb 13, 2016 | Crosley CEDC392JQ Electric Portable Dryer
Dryer not getting hot
If your dryer is not getting hot then it is probably your heating element inside the dryer that has gone bad. They are not hard to replace if you are mechanically inclined. If not, it will need to be serviced by someone who knows how to replace it.
Dec 02, 2011 | Fisher and Paykel Dryers
My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Nov 29, 2011 | Kenmore Dryers
Dryer is getting too hot
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 10, 2011 | Whirlpool WED5300S Electric Dryer
Maytag dryer is getting hot,but taking a long time to dry clothes.
Check your dryer vent see if air is coming out if dryer is getting real hot its dangerous have dryer vent cleaned
Dec 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not getting hot enough
the heat sensor or spark ignitor is at fault
Feb 28, 2010 | Whirlpool LER4634J Electric Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
I have to run the clothes through several cycles before they are dry
It sounds like you have a plugged dryer vent. Clean the vent from the dryer all the way to the outside of the house.
Aug 11, 2009 | Roper RES7646KQ Electric Dryer
Dryer is running fine just not getting hot
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Jul 20, 2009 | Roper REX4634KQ Electric Dryer
My Whirlpool LGN2000PGO not getting HOT
Have you checked the gas valve to make sure that it is functioning correctly?
Feb 13, 2009 | Dryers
Dryers Logo
190 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
