Question about Gateway 7330GZ Notebook
I have taken all of the screws out of the bottom - it still won't open.
I have taken all of the screws that I can see on the bottom. How do I get the machine open?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Take off the keyboard and there may be more screws that show up.
  • 256 Answers
The case snaps together. Try pulling it apart. It is designed to NOT easily come apart, so you will have to gently work at it without breaking anything.
Posted on May 31, 2009
Laptop
most laptops have lots of little screws around the under side.
be very carfull when taken the bottom of as there is ribbins all over the inside.
if you are taken this fan out to clean,,try using a hoover first,just put the hoover to the side of your laptop and try and suck out all the dust from there.
Jul 01, 2014 | HP Computers & Internet
What kind of tool used to open 19.2 charger on bottom?
They are not meant to be taken apart I'm afraid.
May 20, 2014 | Craftsman Drills
How to adjust the carburtor high and low on my weedeater head cutter?
Hi jamesbj44...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know when you go to replace them.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position to start with...you re-adjust when the engine is warm turning the screw in or out till the engine runs smoothly.
The high speed jet is normally adjusted to 1 1/2- 1 3/4 open from the bottom seated positon, then re-adjusted to run smoothly when running at high speed by turning the screw in or out.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
My manual doesn't say how to open the dryer to replace/check the belt
Hi!
A brand and model number would help a lot! Each dryer can open differently.
A lot of them have two screws on the very bottom of the front - kind of hidden. You take out the two screws and lift up the front panel to access the inside. Just lift up after the screws are taken out.
Jan 13, 2011 | Dryers
Cannot open it to replace the filter. How do I open it?
There is a screw on the bottom. That has to be loosened completely and then the front panel pulls off to the left. When you put it back it has to engage exactly or the screw won't screw back in.
Nov 03, 2010 | Oreck Professional Air Purifier Air...
I can get the bottom off of my Gateway 7330GZ laptop
have u checked under the rubber cushions also
Jun 28, 2009 | Gateway 7330GZ Notebook
How to remove the front bumper of a 2001 honda accord
First you need a flathead screwdriver and the socket wrench set.
Pop open the hood and where the grill of the car is should be 4 black clips and you use the flathead screwdriver to take that off. Find the mm sockets that fit on the screws directly above your headlights, one on each side. After that's been taken out, there is one screw on the end of the bumper near the doors. You'd have to get a smaller mm socket to get those out, one on each side. On the bottom are a few more clips and two more screws. Using the same mm sockets that took of the screws above the headlights, take off the screws on the bottom of bumper.
May 01, 2009 | 1998 Honda Accord
Bottom heater quit working
THe bottom usually is screwed onto the unit. I have never taken the kitchen aide apart. If your heat5er is not working for the coffee pot, it is probably the thermo wswitch. A $5 part if you can get to it! Best of luck
Mar 27, 2009 | KitchenAid KCM511 Coffee Maker
Cannot open TS 4500 shredder.
look around on top or bottom for a decal or label covering. A lot of times there is a screw located under it, once you peel back the label.
Jan 17, 2009 | Tech Solution TS-4500 Shredder
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Gateway 7330GZ Notebook Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
