Question about Philips 46PP9302 46" Rear Projection Television
What's the insid of the TV look like?
How Can I rectify the problems below, #'s+letters"r"doubled(ghosting) Has slight distortion in top left corner and along bottom of screen. Have been told one of the prisms may be slightly out of alignment and is easily fixed. I wonder how much is the cost to repair it and canI pls ,If I may download the book for this philips rear projection tv? if so where can i download it and how? Pls reply to mongbeans1@yahoo.com.au In my head I'm picturing a projector that needs to be realigned to the screen. I also have cobwebs showing behind my screen. I'd like to see a photo or manual showing what my TV looks like when I take off the back.
  • 1,959 Answers
Basically, what you have is a convergence problem, very,very common amongst rear projection TVs. Here is a link to a website where the guy shows step by step including pictures on how to fix it yourself. If not, the repair costs anywhere from $250-400. Best of luck.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on May 31, 2009
  • Greg Margossian
    Greg Margossian Jun 02, 2009
    Please rate the solution provided if you feel it answered your question. Thanks very much.
    Greg
Hitachi 50v500, we just put in a new lamp, now the picture on the screen is slightly doubled, what do I do?
Here is what I suggest----look at lettering and or put the mode to 4X3 which is smaller left and right.
Look at the edges of that picture or lettering on screen---this model sometimes has a ghosting where images have a slight shadow, like with rabbit ears.
If this is the case there is a way with the remote to CORRECT IT.
I have the information--confirm if slight ghosting around letters--it can be white or any color.
I have seen this before.
SD TECH
Sep 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Wavy color lines on left bottom corner. letters somewhat blurry.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2010 | Philips Magnavox 9P6034C 60" Rear...
Double printing or 'ghost' images
you need to change your toner opc drums
Dec 13, 2009 | HP LaserJet 1020 Printer
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Philips 46PP9302 46" Rear Projection...
Samsung 42" rear projection tv. Picture is slightly distorted at top left hand corner. All three bulbs seem okay and the mirror also seems fine. It's as if there is an issue before the bulbs. Any...
What's the model number? Describe the distortion in some detail. Is it intermittent? Does it seem to affect anything else, like audio, when it's present?
Bill
Apr 09, 2008 | Televison & Video
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
