Question about Cell Phones
New Nokia 2680 slide. The handset is displays this message when I attempt to dial out, "Call not allowed. Fixed dialling active". This message, can it be de-activated?
    Brigadier General:
  • 7,752 Answers
You will need to reset the phone settings back to it's default.
Posted on Jun 01, 2009
Unlock code for Nokia 2680s -2b
Hi, You can get the unlock code for a Nokia 2680 Slide from http://www.simpleunlocking.com/nokia-2680-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 2680 SLIDE
1 - Switch on your Nokia 2680 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2680 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2680 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2680 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2680 SLIDE
Oct 11, 2012 | Nokia 2680 Slide Cell Phone
Want to open line my nokia
If you mobile displays Open line message means , then it is locked with some network and requires a code to be entered, to allow your mobile to use any network.
Open line (unlock) code for your Nokia 2680 slide model mobile can be got at Superunlockcodes.com which gives easy instructions to unlock your mobile.
Mar 01, 2012 | Nokia 2680 Slide Cell Phone
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
Can you still unlock a phone even if it says cannot undo restriction.
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the Restriction code here
Theunlockspot.com and Unlock it from Network Lock. Follow the instructions and enter the code correct step by step...
Nokia 2680 SLIDE Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 2680 SLIDE mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2680 SLIDE mobile phone, your phone may get hard locked and sometimes become unusable.
Aug 06, 2011 | Nokia 2680 Slide Cell Phone
My nokia 2680 slide phone had a problem it cannot press the ok buttons and call buttons pls help what can it do to resolve thes problem... tnx
hi torre,
the problem is with your keypad as the ok & call buttons are mostly used in the phone the pad inside the phone gets punched so it doesnt respond when we press it.
so, u have to visit the nearest nokia service centre to repair the handset.
Regards,
Prakash
May 08, 2011 | Nokia 2680 Slide Cell Phone
How to deactivate fixed dialling
Hi
Fixed dialing is a network-based service which should not be active unless you specifically ask them for it, perhaps it has been activated on your account by mistake and another customer is wondering why it doesn't work for him.
You would have to get in touch with your network operator to deal with this.
However, it may be possible to activate/deactivate it through the phone if your network supports this option. But requires a Pin2 code that can ONLY be provided by your network
You can go to Contacts > Options > SIM Numbers > Fixed Dial Contacts > Options > deactivate fixed dialling > Enter Pin 2 code.
Otherwise, put your SIM card in another phone if possible to see if you get the fixed dial issue still. If yes, please contact your network for assistance.
Good luck.
Aug 31, 2010 | Nokia 6263 Cellular Phone
Can make outgoing calls but cannot receive calls. The caller to my phone gets a message of number unobtainable. phone is a nokia 2680 slide
Make sure all call diverts on your handset are cancelled or inactive.
If they are and it still does this, then it is a network issue, which means it cannot be fixed by you. You need to call your network/service provider, as the problem is at 'their end'
Jan 04, 2010 | Nokia 2680 Slide Cell Phone
Handset is displaying than pin 2 code rejected
you can call to your network provider customer care and ask for puk2 code by using this you can unlock pin2 code . hope you will succeed....
Dec 10, 2009 | Nokia 1600 Cellular Phone
It cant take a free tone or send picture messages
you need to call the customer service to activate your MMS service. they will send you a service message
Nov 12, 2009 | Nokia 2680 Slide Cell Phone
Making a call and sending a txt message is not allowed
go to messages and then message centre and put the cmessage centre number
Dec 25, 2008 | Nokia 3600 slide Cellular Phone
Cell Phones Logo
148 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
