Question about Bosch Refrigerators
Fridge not getting cold Bosch KGV36390/05
I just purchased a used Bosch fridge. The problem is that it does not get colder then 8° Celsius. The bottom freezer works fine, meaning it gets very cold -17 Celsius.
The compressor will turn on only for a few minutes or so and then turn off and wont turn on again until a few hours later.
Is this a thermostat problem? It has a turn knob on the top to control the temperature and even on the highest setting it does not get colder.
Or does the system need a refrigerant refill?
Thanks!
  • Anonymous Mar 31, 2014
    colder than thermostat setting
    Novelist:
  • 103 Answers
Hi: It shouldn't need a recharge as your freezer is cold, and that's wher the fresh food section gets its cold from via a fan. If your vents are blocked with too much food in the freezer this will happen. If you have a problem with the defrost heater or timer frost will build and block the port to the fan, causing a warm fresh food section. If the circulating fan is out your f.f. section will get warm. It's a small fan not to be confused with the condenser fan below (at the grill.) Here's a question for you. Did the fresh food compartment work for the first week or two? That's how long it would take frost to build and jam the system if your defrost system is out. If this is the case you can unplug it and put your food in a cooler. Melt the frost with a hair dryer carefully avoiding plastic components. It will then work for a week or two before it fails again. It will get you buy until you get service. If you do it yourself... Look for the defrost heater in the freezer and see if the coil of wire in the glass tube is broken. You will need a service manuals or a parts list with a diagram. Sears parts on line has a good database of parts and diagrams. Hope this helped, Jeff
Posted on Jun 01, 2009
Is +2 the coldest temperature
If you go lower the fresh produce may freeze and that is not good. A fridge should be no lower than 4 Celsius and no higher than 8 Celsius for optimum storage. I don't think there would be any reason to go below 2.
Jul 30, 2017 | Bosch Refrigerators
The compressor in the fridge energises for a constant 30 mins in every 90 mins. Is this normal?
depending on door seals and the number of times the door is opened and the temp setting on the thermostat and the positioning of the fridge it could be considered normal
see if you can get an idea of the cycle times at night when the fridge is not being opened and the room is cooler if the temp setting is close to 32 or zero celsius then the fridge works hard to maintain that low setting but if the setting is higher say 5 degrees celsius it runs a lot easier
the problem with fridges is that every time the door is opened , all the cold air falls on the floor and the motor has to run to fill the fridge with cold air again
fridges that are full of food maintain their cold better than empty fridges
May 04, 2016 | Refrigerators
I have got a Bosch KGV36NW20G Fridge Freezer and it's only 2.5 years old. Some problem has occurred recently. I can hear that water or some fluid is flowing around in the Fridge Freezer all the time, which...
From your description, it sounds like your condensing coil is dirty and needs cleaning. You will probably find the coil and fan inside the back cardboard cover area. Once a condensing coil gets so dirty, the refrigerant condensed in the condenser is so hot that it does little cooling effect because of the internal heat consumes any refrigeration effect left in the refrigerant. This is vary common problem and especially for pet owner. The pet fur and hair get caught in condensing coil and block air flow.
Hope this helps
Dec 09, 2014 | Bosch KGV36NW20G 60cm Classixx...
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
My fridge is warm doesnt cool down the things inside only the chilly colder box is cold and it freezes down the meat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Bosch Microwave Ovens
The fridge is frozen - the temperature guage says 6 degress celsius but everything in the fridge is frozen solid!!
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 30, 2009 | Refrigerators
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
1,255 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
