Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
GE Upright Freezer problem/door
The door no longer makes swoosh vacuum sounds when closing. also the bottom of the freezer is thawing out.   I did defrost the freezer, but this didn't help the problem.  Any other ideas?
  • Kenmore Master
  • 4,655 Answers
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Posted on Oct 24, 2007
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Apr 18, 2014 | GE FUF17SVRWW Upright Freezer
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Is there a vacumm pump to displace air in freezer
Vacuum relief port on all upright freezers allows easy re-entry after door closings. This is located on the door bottom.
Dec 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
Upright freezer--manual defrost
I would check that the door gasket makes good contact with the cabinet. If it does then I would check the temp inside the cabinet. If you have large buildups of ice on the evaporator coils then I would suggest defrosting the freezer and see if that makes a difference. Hope this helps.
Aug 10, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
416 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
