Question about Stanley Bostitch Coil Framing Nailer
Stanley Bostitch Coil Framing nailer blows head off of nail?
Sometimes it fires without a nail; othertimes it blows the head off of the nail? The nailer is old but worked fine until recently.
    Sniper:
  • 79 Answers
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
Posted on Jun 18, 2009
The framing nailer blows air out the exhaust,and will not fire a nail when I pull tre trigger
take of clylinder head when off there is a large button make sure its fre should work like a door bell switch grease slightly and put together again
Aug 28, 2011 | Stanley Bostitch Coil Framing Nailer
Bostitch electric nailer shoots two nails at time, how do I fix?
Generally this is because the feeder gets stuck. Usually when this happens to me, I oil the area and fire the guna few times without nails in it. All that is usually needed is either more lubrication or a good cleaning. See the following link for a diagram of the unit to guide you in dis-assembly and re-assembly. Enter the model number at the main page.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CK232OvOu6MCFZZM5Qod4gz2bg
Aug 13, 2010 | Stanley Bostitch Coil Framing Nailer
My bostitch n63cp coil framing nailer blows air continuously near the trigger and does not shoot the nail. What is wrong and how can I fix it?
Replace the trigger valve assembly. Part TVA6. It takes just a few minutes. The part will include a pin punchout tool, you supply the hammer.
Jun 28, 2010 | Stanley Bostitch Coil Framing Nailer
Bostitch coil nailer does not cycle. Sounds like a large internal air leak
drive pin o ring is shot. deair the gun remove top pull drive pin replace oring oil the heck out of it and go to work
Nov 30, 2009 | Stanley Bostitch Coil Framing Nailer
Have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Nov 25, 2009 | Stanley Air Tools & Compressors
N80CB - Coil Framing Nailer firing plunger stuck
There is a number of reasons that this will happen. Is the driver (plunger) physically stuck? Take a small screw driver and see if it can manually be pushed back. It may also be a broken head valve spring, or a stuck head valve (you have to remove the rear cap to get to these parts) Maybe this unit just needs an O-ring kit. Try these things and let me know
Apr 02, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch Coil Framing Nailer Logo
272 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
