Question about Dryers
I have the ge harmony dryer and it is not blowing or heating i did the reboot it worked a few times now it wont reboot and says to check blower motor and element i have a hard time believing that it is either or because when it reboots it works fine for 5 or 10 loads
  • ringo5589 Jun 01, 2009
    i went over this thing with a fine tooth comb it has been apart no bad solder joints no bad connections i can see i'm leaning towards a inverter because the blower is reading good any other suggestions
    Brigadier General:
  • 8,619 Answers
Hi
Please check for burnt connections or loose connections on the element. For that you'll need to remove the drum as it is at the back. Please check this link to see the connections.
Check with wiring diagram ( usually found in console area or under the dryer top panel ) for specific wire colors and terminals on the timer and selector switch. Also check for the thermal fuse and the operating thermostats right, it is right beside the motor on the fan blower housing. Safety thermostats can always be found on the heating element cage housing.
Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 01, 2009
  • 3 more comments
  • Rylee Smith
    Rylee Smith Jun 02, 2009
    Hi
    Have you checked the wiring diagram ( usually found in console area or under the dryer top panel ) for specific wire colors and terminals on the timer and selector switch. Also check for the thermal fuse and the operating thermostats right, it is right beside the motor on the fan blower housing. Safety thermostats can always be found on the heating element cage housing.
    Thanks
    Rylee
  • Rylee Smith
    Hi!
    Please check the things as under:
    Check for any blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
    Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
    There's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
    Another problem may be the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Oct 20, 2009
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith May 08, 2010
    This is also a stuck premium and required to be deleted.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith May 30, 2010
    Dont know if your issue is resolved however, it's been a year that this premium is stuck on My Home page.
    Sergeant:
  • 187 Answers
Please try this link
http://www.acmehowto.com/howto/appliance/dryer/diagedryer.php
please rate my suggestion............
  • Dryers Master
  • 19,396 Answers
If you have an error related to heating system, that usually means that there is a fault in there.
The fact that machine works fine for few loads may significate that the problem is related to vibration>
check for a bad contact to fan and to heating element. A bad solder joint to the fan , for example will cause failure related to machine vibration, triggering the error mode only once in a while.
A faulty control board causing the same problem is quite unusual.
The element can be tested reading ohms at the terminal. The fan is tested by energizing. In this case sometimes you find out more observing visually the solder joints rather than using multimeter.
Regards.
Posted on May 31, 2009
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
May 14, 2010 | GE Profile Harmony DPGT750EC Electric...
No heat and blower doesnt blow
If one of the two thermal fuses are blown you will not get heat. Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow through the machine. Check and make sure your exhaust vent is not clogged. Clean it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the machine when it is turned on. If not you have a blower problem.
Turn the power off to do this. The thermal fuses are located on the element casing. They each have two wires coming out of them. They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across. Goodluck, Dont forget to rate me as fixya..
Jan 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
The blower and heat are not working my ge harmony electric dryer
If blower isnt working you wont feel any or very little heat in the drum
Aug 19, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony gas dryer- no air flow in or out no heat
Replace the blower motor. Check condition of blower wheel and replace if found defective
Jan 16, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Blower doesn't blow and no heat
With these GE Harmony Profiles, the blower is the problem in same situations about 95% of the time.
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Oct 18, 2008 | GE Profile Harmony DPGT750EC Electric...
Blower & heat
Most common problem on this unit is the blower motor. It needs replaced not the control board.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating!! Harmony dpgt750ec
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, mca0824@aol.com
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
81 people viewed this question
Top Dryers Experts
