Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Freezer is building up frost and refrigerator is not cold enoough
Amana bottom freezer is building up frost and the refrigerator on top does not seem to be keeping items cold enough
    Problem Solver:
  • 15 Answers
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Fan is not blowing cold down bottom
Hi my name is Sean. Could i get some more info, Do you see frost build up on the back wall of freezer, when you say no cold air, is that no air at all or just no cold air? And is the freezer cold or warm?
Thanks
Mar 26, 2011 | Amana ATB2232MR Top Freezer Refrigerator...
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
642 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
