Question about Hitachi 55FX20B 55" Rear Projection Television
Low voltage power supply problem
Blows fuse to power supply,jumped out fuse, red led came on and stayed on none of the five green leds came on. suspect m6511 ic and or related diodes problem
    Scholar:
  • 150 Answers
Hi, I agree that the regulator IC is probably toast but you`ll need a service manual to figure the rest because none of the leds are on which means NONE of the secondary supplies are running, check the chemical fuses and I`m sure some will be open. you can go to encompass parts on the internet to order the sm, trust me you`ll fix it a lot faster, gl, video-tek
Posted on Jun 05, 2009
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have a reebok crosswalk rt 5.0 treadmill. I can calibrate the incline and it goes up and down. however when you press the button to raise the incline the incline number will change but the machine does...
Step 1:
see this details and proceed according. God bless you
LED.
Step 2:
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Jan 07, 2013 | Reebok Exercise & Fitness
Picture will not come on
A few questions and a suggestion:
Do you get sound? Does power light stay on?
suggestion:
Unplug set and remove back cover---set will have several green led lights on board in power supply and one red one.
Red one should be on. While looking from the back have someone turn set on---note if all the green led lights come on and if one or more go off before the others you have located your problem.
The green LED's monitor voltage sources in the set's power supply.
I have more ideas but need more info from you.
If this helps rate this solution as very helpful as I do this here for free.
SD TECH
Aug 18, 2010 | Hitachi 50DX01B 50" Rear Projection...
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Standby LED stays red.
This can be a combination of things. The main power supply may have failed, or there is a short putting it in to protect mode. It is also possible that the back plane supply and or lamps have failed.
Jerry G.
May 13, 2008 | Philips 32PF9964 32 in. Television
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
