Question about GE JBP30 Electric Kitchen Range
I have a GE electirc stove JDP37GT1BB The blower that cools the oven doesn't turn off at all
  • 378 Answers
If that blower that cools the oven is auto run and off automatically, then maybe the thermostat that controlling it, was damaged.
Posted on Jun 01, 2009
How do I unlock GE Profile Stove after oven cleaning cycle
there has to be a release lever someplace that does not require removing tho top . GE Profile did something like this this morning! It held the ... Is there a small hidden lever right below the stove top above the oven handle? another site said to wait till it cools down and then it will open but you might have to set temp and restart the oven
Feb 06, 2015 | GE Kitchen Ranges
Why does the f1 code appear when cleaning my oven
Its an error must be the blower motor..one blower will blow air to cool tge chamber. try to open the unit & look inside
Sep 20, 2014 | General Electric Ge Stove / Oven / Range...
I HAVE A GE OVEN AND AFTER GOING THRU CLEANING TIME OVEN WILL NOT UNLOCK
Hi, After time has finished you need to let the stove cool down. This will take a few hours. Then it will open. Make sure door is not jammed. Good luck.
Mar 17, 2014 | GE Ovens
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Need ge jgsp22 gas slide-on ranges installation instructions
does the pilot light work and when you turn it up the flame should torn up if not the thermo cupler is faulty
Nov 21, 2011 | GE JGSP23 Gas Kitchen Range
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
GE JBP30 Electric Kitchen Range Logo
192 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
