Question about Dell WL6000 Computer Speakers
I can not get it to play as a surround sound system
I can only get sound out of two of the speakers.  I can't get anything out of the rear front or subwoofer.
  • lexter_wolf Oct 23, 2007
    The computer is brand new so it was shipped to me around a week ago from Dell
    Brigadier General:
  • 6,966 Answers
Hi again,
I responded to your other post after we lost the live session.
Here's the link  to that post.
Posted on Oct 23, 2007
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
I'm having trouble with sound when i try and install a surround sound system. This is the second system I've had that my lg would not play sound
Firstly you must have the remote typically to set the speakers up or there is a combination of keys to do this but usually some functions cannot be changed without the remote.
Second, the surround sound playback can only be played if the sound that you are listening to has the surround sound track, otherwise you may not hear hardly anything when your device is set to the wrong function.
The speakers must also match the surround sound system otherwise you may not hear anything at all.
Remember: A 5.1 System is 5-speakers,   A 7.1 system is 7 speakers!
The speakers should be marked for which place they belong LF= Left,Front...etc.
Jun 12, 2010 | Audio Players & Recorders
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Jan 17, 2010 | Audio Players & Recorders
No surround sound with Prima HT-TW57P DVD System
I realize this may sound silly but it could be the disc your are playing. Some DVDs are not mixed for surround sound and thoes that are produce very little sound from the rears.
Rear speakers were meant for effect, not meant to distract you from the picture.
Give this a try, get a movie playing that is 5.1 surround sound. Check that the home theatre is not set to stereo mode, if it is change the surround mode on the unit. Now that you are in the middle of an action scene disconnect the front speakers and see if there is background noise comming out of the rears.
If its still dead let me know more details about the system and I will work on a solution.
Cheers,
Jan 06, 2010 | Televison & Video
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Dell WL6000 Computer Speakers Logo
53 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
