Question about Acer Aspire™ T180 PC Desktop
Door spring fell off I can not get it back on to work
The door for the disks fell off. there is a small spring that shuts the door I cant seem to get it back on that it should shut the door
  • 46 Answers
Not much I can help with here, except maybe grab two tweezers or two small needle nose pliers and try to get that spring in there. Will take a try or two, but you'll get it.
Posted on Jun 01, 2009
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
1989 s10 blazer the door handle broke off we went threw the window to unlock the door. We lost the small spring that unlatches the door from the frame. I got the door finally open with a screw driver....
the interior trim will come off to gain access to the lost part. Get a telescopic magnet which will retreive this part. If it is the striker the latch hits and keeps the door safley shut That is what I think your refering to. The striker bolts to the B pillar which keeps the door shut. Also the striker should cost no more than $15 to 20 $$ to replace. Maybe less
Aug 07, 2011 | Chevrolet Blazer Cars & Trucks
Door on whirlpool oven will not go back on.
To remove you lowered the door all the way down. Then lifted the door out. If he hinges were then moved to the shut position you will have trouble getting it on.
If this is correct so far...
push the hinges back down and try again. It can be tricky. It should go on.
Adrian
Mar 07, 2010 | Kitchen Ranges
I have a Frigidaire FDB2410LDC3 Dishwasher. It was working great until my 5 year old fell on the door and it does not spring back up now. I tried looking with a flashlight in the sides and the springs...
Prhandle and latch.obably sprung the hinges. The reason it dont want to work right is the door latch is not latching properly and therefore it wont start. I would start by replacing the hinges and springs and the
Dec 30, 2009 | Dishwashers
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Small spring found
that spring is the door open hold spring.
Mar 13, 2009 | 2001 Jeep Grand Cherokee
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Door of microwave wont shut
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
If you need to order parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
After you look into this, if you still need help, please write back with your model number and more details.
Oct 08, 2008 | LG Microwave Ovens
Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
May 04, 2007 | GE JT912SKSS Electric Single Oven
Acer Aspire™ T180 PC Desktop Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
