Question about Frigidaire 24 in. FDBB944C Built-in Dishwasher
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
Frigidaire fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
Posted on Apr 30, 2010
  • 6,784 Answers
CHECK THE FOLLOWING AREAS FOR FAULTS--
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jun 01, 2009
No power lights
Check circuit breaker to see if it is on, Then check the wall outlet to see if you have power to the machine. Turn off the breaker and open the control panel. See if there is a blown fuse. If the fuse is either not there or is not blown, turn the breaker back on and CAREFULLY measure the input voltage to the control panel main switch. If it is not there, check the door safety switch to see if power is there...Lots of troubleshooting...Have fun!
Dec 27, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Blinking lights on frigidaire dishwasher
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
All lights flashing wont turn on
1) test the c.breaker or blown fuse and replace
2) test any wires connector loose
3) clean any wires connector
4) Board is faulty. try to run the diagnostic system.
5) Otherwise call the frigidaire for assistance online chat.
God bless you
Jun 18, 2012 | Frigidaire Dishwashers
Frigidaire Model Number FDB1100RHM0 Dishwasher does not do anything. All switches on front panel seem to work and the water is turned on
proceed with this step:
Power from the house
test for some blown fuse or c. breaker reset.
Door switch
if the swtich door if open or defective, will not start the machine see the wiring diagram attached.
Wiring
see for wires, burn, breaker or loose repair.
Timer or selector switch
test the timer, for contact dirty, or corred, clean, and tigh the wires loose see the diagram attached.
May 07, 2012 | Frigidaire FDB1100RHM Builtin Dishwasher
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Jun 21, 2011 | Whirlpool Dishwashers
My burners work on the stove but the clock, and over buttons will not come on, so I'm unable to turn on the oven. I have a Frigidaire model FEF366EMC
Check for a blown thermal fuse protector. Located on the back wall of the oven behind a sheet metal cover. Disconnect power and you can ohm it out.
Jun 27, 2010 | Frigidaire FEF366 Electric Kitchen Range
No power and its not the breaker.
Some dishwashers have a thermal fuse located behind the console attached to the main board It is always helpful to include model number off unit as Sears does not make any appliances, they just sell them made by other companies with the kenmore name on them. You could have a GE, Whirlpool, Frigidaire, etc....
Mar 13, 2010 | Dishwashers
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
No power
perhaps you should check the fuse in the plug and in the breaker,if there is still no power maybe a circuit has blown in which case you should call yhe manufacturers for qualified technicians.
May 05, 2008 | Frigidaire GLD2445RFC Stainless Steel...
Frigidaire 24 in. FDBB944C Built-in Dishwasher Logo
2,448 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
