I recently bought the pro-97 from some one else. When I turned it on it saysclone mode, press up to send. Remove cable to exit. The problem is that it is not hooked to anything other than the atenna that came with it. I cannot exit. When I push the up arrow it reads confirm to send data? 1-> yes press other for no. when I press 1 it says clone mode sending data. Then it said finished and went back to original screen.Please help.
If I understand your question correctly, the answer is yes. The PRO-97 and 2051 cover the same frequencies and the same trunking systems, so you can program the same information into both. There is, however, no cloning capability between the two, so all programming will have to be done manually. Once it's done there is no way to synchronize the two units, so the chances of both receiving the same signal at the same time are remote.
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF. 2. Turn the scanner ON. "Multi-system Trunking Scanner" appears. 3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears. 4. Press the 1 (one) key. 5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Could the display be saying "wired"? This is what it shows when it is in cloning or programming mode. If it is showing this and there is no programming or cloning cable attached, check the programming jack to see if it is damaged.
GAMEPLAY CONTROLS Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships. X Button Select. Action. Triangle Button Cancel. Close Menu. Square Button Pan Camera (Hold) Circle Button Snap Camera to Sim L2 Button Sim Switcher Menu (Hold) L1 Button Freeze. Fast-Forward. R2 Button Toggle Walls On/Off R1 Button Freeze. Fast-Forward. Start Button Pause Select Button Toggle Control Mode Left analog stick (L3 Button when pressed down) Move Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS X Button Place or Grab Object Triangle Button Cancel. Back. Square Button Remove Object and Put In Inventory Circle Button Toggle Blueprint Mode L2 Button Clone L1 Button Rotate R2 Button Undo/Redo R1 Button Rotate
BUILD/REMOVE MODE CONTROLS X Button Place/Remove Wall, Wallpaper, or Floor Triangle Button Cancel. Back. Square Button Pan Camera Circle Button Toggle Blueprint Mode L2 Button Clone Wallpaper or Floor R2 Button Undo/Redo Combo #1 L1 Button or R1 Button + X = Build or Fill Room Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
How To Clone a BPR40 Radio Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio. 2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice. 3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio 1. Turn off the radio. 2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times. 3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures 1. Connect the cloning cable to both the Master and Slave radio. 2. Press and release Programmable Button 1 of the Slave radio. 3. Within 2 seconds Press and release Programmable Button 1 of the Master radio. 4. The LED for both radios show flashing orange during cloning. 5. Once cloning is completed, an
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
DO NOT GO BUY ONE FOR 23 BUCKS PLUS SHIPPING!!!!!!!
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input. You either have one or know someone who does that you can borrow. If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off. Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on. They should say "clone". Now press the" ENT" on the good radio, This will send the data over to the "bad" radio. Now turn them both off, remove the cloning cable and turn them back on. Both should be working now. \WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells. Some times this can extend the battery's life.
MOTOROLA GP-2000 Programming Instructions Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If
the radio is turned on, turn it off. Press and hold the MON button and
turn the radio on. A ringing tone will be heard,which indicates that
the radio is in Programming mode. The PW and [] indicators are
displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Thanks so much!
