Question about Miele CVA4070 Coffee Maker
What is F81 on a CVA4070 Mieled coffemaker??? the owners manual addresses F10-17 and F73, but no F81 any ideas???
F81 means that the steam heater does not work properly....(possibly a blown fuse or a broken heater..could also be the main power board TRIAC) good luck!
Posted on Oct 24, 2013
Drip Tray is filling up after each use. I cleaned the sensors but it is still filling more than normal on final rinse.
KAREN, LOOK IN YOUR MANUEL SEE IF THERE IS MANUFACTORE PHONE NUMBER CUSTOMER SUPPORT THEY WILL GUIDE YOU BEST AND CORRECTLY! LOOK ON INTERNET TYPE IN ADDRESS SLOT www.miele model cva4070 customer service phone number hit enter!
Jan 10, 2016 | Miele CVA4070 Coffee Maker
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Coffemaker brews half a cup it says descale it need to know how
It will be in the owner manual, it usually is something like vinegar run thru the unit but check the manual first. If do not have the manual Google the full model number with "manual" to try to locate one.
As a last or first resort you can always try to call the maker's customer service number for live help.
Dec 17, 2012 | Keurig B70 Platinum Brewing System
When the brew unit open to put the waste into the container, this part of the unit stay open
OK I had this precise problem .. initially I got F73 occasionally and then increasingly more frequently over about a 2 week period. When the error comes up the first problem is that you cannot remove the Brew Unit. The Correct procedure is to enter Service Mode and then you have the option of resetting the position of the Brew Unit. For instructions on this consult the Service Manual which is available online for free ... just search for 'CVA4070 Technical Information'.
Now in terms of what can cause this (as the manual does not explain the reason for the fault in my case) ... at first I thought it was the Brew Unit getting sticky and thus too hard for the motor to return the unit to its home position. The motor is actually very strong due to internal gearing and this is unlikely to be the problem unless it's very stiff. In my case it turned out to be one of the two reed switches on the back of the motor drive was very slightly worn (it wears out because it drags on a cam) and this prevented the motor drive from stopping at precisely the right position during the sequence. This then resulted in the machine getting confused about what state the brew unit is in and so it says F73 . The two reed switches that control the Motor drive are accessible from rear of machine by removing the black cover of the motor drive. I can't recall which one was at fault for me .. but if you operate the machine with the motor drive cover off ... and then reproduce F73 ... you can actually see that it has not stopped in the right place on the reed switch and then you can work out which reed switch is causing the problem (also refer to manual which has a good explanation of states). There are two other read switches in the machine of the same type and these are not critical in terms of the wear issue so you can swap these over for the brew unit ones. Alternately you can buy new ones. It's a simple job just to replace them and the Miele service person would probably do it in 10 minutes. Now problem is fixed.
Now if you're doing this yourself ... you should also do some servicing at the same time;
1. Apply grease to the cam that controls the reed switches (this will prevent wear of the reed switch buttons).
2. On the back of the Brew Unit at the top .. there is lever that has ridges on it that activates one of the other reed switches (grinding amount compensation). Apply grease to this. (This can also stop an annoying clicking sound each time you brew coffee).
3. Apply grease to O-ring on the spout of the coffee on inside of door
4. Clean back of machine with vacuum cleaner and then with warm water .. it get fairly dirty. You can take pieces off to clean more thoroughly
5. If your technically skilled .. remove the Brew Unit Drive .. disassemble, clean & re-grease. After 5 years or so its gets dry and you do not want to have to replace this unit. WARNING: Note position of cogs and the cam before you disassemble (ie take pictures) and make sure you put it back in the same way. I did not do this and I broke the plastic cam .. which is designed as a weak link so that metal gears inside motor and brew unit drive are damaged.
Finally ... coffee machines are high maintenance and even Miele ones break-down. Miele spare part prices are very high but what I like about this machine is that it is designed to be serviced.
Oct 29, 2012 | Miele CVA4070 Coffee Maker
Just got a maytag bravo electric dryer, had a storm electricity went out and now the dryer won't work. It has a code of F73
An electrical storm can cause high surge voltages which can cause damage to sensitive components.
You wll have to check the manual to decode the F73 error message.
I presme you've unplugged the device, waited (say) a minute or two, and then plugged it in again ? Doing so will reset most of the electronics (assuming no damage) and has been known to solve some odd symptoms.
Jun 08, 2011 | Kitchen Ranges
Cleaning instructions
Cleaning instructions are on page 34-45 in the owner's manual.
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback. Thank you.
Jan 03, 2009 | Miele CVA4070 Coffee Maker
How can I set the automatic timer on the Krups FME2 Coffemaker
Problem solved...
Found the manual for my coffemaker online
Dec 15, 2008 | Krups FME2 Coffee Maker
I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Miele built-in coffee machine. I've set the wrong language. How do I reset it back to English? Please help.
Language setting is on page 19 of the owners manual =>
Please leave feedback Thank you.
Nov 04, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
291 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
