Question about Sony VAIO PCG-Z1WAMP1 Notebook
My Sony Vaio PCG-z1wa suddenly shuts off if the battery is not attached. In other words, I have to be constantly charging the battery or it would shut off all of the sudden. It obviously seem like it is an electrical problem inside the computer. Any ideas of whjat the problem might be and how to solve it??
  • 674 Answers
There are a lot of cuase on auto shut off the laptops..
posseble if..
1. if the battery not inserted on laptop... it means you using the charger when you disconnect or loss the connection, auto shut off.
2.if the battery inserted and full of charge.. then make auto shuto off.. this problem,, sometime overheating,, A. fun not working properly..B. shortage of cheps.
try to check the charger and battery,,, use another charger to test observe atlest 30minuts.. the problem the sam auto shut off.. check the cpu fan.. or processor
note" if under warranty don't open it. bring to warranty..
Posted on May 31, 2009
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
My laptop turns off unless under constant charging
may need a new battery if not holding the charge
Aug 07, 2012 | Sony VAIO PCG-TR1AP Notebook
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Charging or power problem
check the cpu and that is shortage.., check the other power ic something bad ic need to replace..
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
Shuts down on AC in less than 3 minutes after boot but not in safe mode. Works fine on battery only. Charges battery fine. DC output voltage 19.77 VDC. Sony Vaio PCG-K35
Sorry about your SONY problems.
You may want to try another charger,
Your charger changes your input voltage from A/C 120V / 220V to a constant regulated 19.77 ? Volts DC. or direct currant.
If your charger is allowing to much A/C to pass to the Unit, the unit may charge OK but with sense the incoming and as a protection, will shut down the power source.
I would take the charger to a Radio Shack or maybe someone qualified to check it !
If the charger is fairly old and you live in a lightning area, this may be the case.
If your unit will run without the charger attached, Boot it up regularly ( not in safe mode ) and make sure the battery if not at fault.
If you have a battery check utility !
Hope this information has helped you with your problem.
John Ray
john@johnrraycomputer.com
Readers, please rate your technicians information.
Jul 12, 2009 | Sony VAIO PCG-K35 Notebook
Sony VAIO PCG-Z1WAMP1 Notebook Logo
365 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
