Question about Acer AC711B 17" CRT Monitor
Moniter won't turn on
Hey yesterday i turned comp off and moniter aswell with the power button on it and now when i turn it on the screen just flashes a green light on and off when its plugged into the comp and just stays blank when its not in can any one help me plz thank you
    Genius:
  • 1,003 Answers
SOUNDS LIKE POWER SUPPLY IS OUT OR POWER RELAY IS Bad.
Probably cheaper to replace this mointor with a new lcd which uses 50% less current.
even if you find the parts to fix it i suggest replacing this moinitor altogether electrical failure is a sure sign of other problems in the future.
Posted on Jan 16, 2008
SOURCE:
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
I have an Acer AL2017 20inch. As of recent the
try these steps - in this order:
  1. Download the latest drivers for your video card but do not install it yet.
  2. Uninstall any video card software installed (ati catalyst/control center - nvidia etc)
  3. go to device manager, expand video adapters, and right click to uninstall them both.
  4. Reboot your pc. Windows will install a generic driver when it boots up. From there, install the new video drivers you downloaded in step 1.
  5. Get the monitor driver here: http://www.zdnetasia.com/downloads/pc/swinfo/0,39043052,50002410r-39518824s,00.htm and install it
  6. That should fix it. Let me know what happens.
Aug 08, 2009 | Computers & Internet
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Blank screen
Hey I am also facing same problem.But My card was woorking fie before yesterday.
I bought a new CPU cabinet> so had to remove nad reinsert the GFX card and it giving me the same problem as you are facing....
i.e. the fan is moving but screen is blank
Help plz.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Monitor won`t light up.
Something got faulty on the power section.
I suggest you take it to those who knows about its technical.
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
My gateway GT4010
check the power plug first and see if it is properly plug in and turning on the power button, if does not work, get a new power plug and try as i've said again and if does not work the power system has problem and should be changed.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Moniter problems
the monitor have a problem
just replace the monitor
Oct 23, 2007 | Relisys TL 700A (White) 17" LCD Monitor
Will not close down
These monitors go into a standby just incase you are only restarting the PC.
To turn it off properly, hit the power button on the monitor before Windows has completely turned the computer off.
IE: tell Windows to shutdown, when you see the blue screen telling you Windows is shutting down, turn it off then.
Hope that helps
Oct 20, 2007 | Acer AL1715 17" LCD Monitor
Acer AC711B 17" CRT Monitor Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
