Question about Hotpoint HSS25GFP Side by Side Refrigerator
Model HSS25GFP--Water dispenser working fine, ice is not being made. HELP
    Novelist:
  • 103 Answers
Hi: As summer approaches our refrigerators especially the freezer side warm up. Your freezer has to be at 0degrees to harvest ice. Set your freezer colder and don't trust cheap thermometers. Also don't do the human thing and check the freezer every 30minutes to see if ice is made. It will take 24hrs at zero degrees and opening the freezer a lot will not help matters. Hope this helps, Jeff This happens to me every summer.
Posted on Jun 01, 2009
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Aug 08, 2010 | Hotpoint HSS25GFP Side by Side...
My ice machine works fine but I'm not getting any water to the outside button to receive water.
Hi .. ypur problem is likely that the tube running to the water dispenser is frozen .. you should defrost the unit and free the water tube of any ice or obstruction.
May 03, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
WHY DOES THE WATER WILL NOT DISPENSE WHEN LEVER PUSH IN
I think your water dispenser switch is broken behind the area where you press your cup to get water. Go tom site below and enter the model HSS25GFPAWW into model search feature and it takes you to a photo of the switch #72 in photo The part number is different WR23X10224 I could also be mwrong but if you need to contact me my email is appliancepartsse@yahoo.com http://servicepartstec.blogspot.com/ <site
Jun 10, 2009 | Hotpoint HSS25GFP Side by Side...
Ice not dispensing and water not coming out
Our ice maker is not working..water is coming out just fine...the bar is down but not making ice...stylnd@comcast.net
Mar 04, 2009 | Hotpoint HSS25GFP Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
No water
MORE LIKELY TO BE BLOCKED OR A KINKED PIPE AT BASE OF DOOR, WHEN YOU ACTIVATE THE VALVE THE WATER FLOWS STRAIGHTOUT OF THE DISPENSOR SO THE MUST BE A PROBLEM IN THE DOOR AREA. REGARDS DVISOR
Aug 24, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
143 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
