Roland Juno-D
Problem for Roland Juno-D
My sustain pedal does not work on my Roland Juno-D keyboard.
By phillipldavi on May 31, 2009
When I plug in my new sustain pedal to the Roland Juno-D "hold" input and attempt to use it, the pedal doesn't affect any notes played. Any help would be appreciated.
Best Solution
posted on Jun 01, 2009
Helpful)
scspriggs
Rank: Guru
Rating: 91%, 602 votes
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
Comments:
Aug 19, 2009
- I ran across this post again and realized I didn't read what you wrote carefully enough -- too much of a hurry.
I was thinking outboard sustain pedal, I see now your issue is with the sustain pedal which plugs into the keyboard.
I would suspect that it just needs cleaning. The pedal is a switch which essentially connects the contacts in the keyboard jack. The plug on the pedal is probably not establishing good electrical contact.
You can check the continuity of the pedal itself by using a multi-meter on the continuity setting, putting one probe on each section of the pedal's male jack, operating the pedal, and see if you get continuity between the tip and ring of the male jack.
The remedy would be to spray electrical contact cleaner into the jack on the keyboard and to clean the male jack on the pedal with very fine sandpaper -- then wash it down with cleaner.
If this doesn't correct the fault, the switch inside the pedal would next be suspected -- take the pedal apart and clean the contacts in it as well.
If fault still not corrected, I would suspect the jack in the keyboard -- the keyboard will have to be partially disassembled to get to that.
If that doesn't correct the fault, the problem is likely in a circuit board. This diagnostic is probably best done by a repair shop.
Charlie
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Roland Juno-D
Questions and Unsolved Problems for Roland Juno-D
Do you recommend Roland Juno-D?
Answer
Answer
Repairing the function buttons on the Roland RD 500. I have a broken button on my selection section... (More)
Answer
I have a model Roland E09 key board recently purchase on Jan2009. But I found a problem to oparate... (More)
Answer
I can't find a Juno D driver for vista!
Answer
I'm just wondering how to layer patches on my Roland Juno-D. The manual doesn't help much. For... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Roland Juno-D:
Top Musical Instrument Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Musical Instrument Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
