Question about Williams 2509612 Ceramic Mid-Size Heater
Kirkland Patio Heater shuts off after 60-90 seconds
I am having the same problem; I took everytinng apart and cleaned the lines and it is still shutting off after about 60-90 seconds. Should I order a new pilot assembly?
    President:
  • 3,433 Answers
Thermo coupler is faulty.
Posted on Jun 01, 2009
The Kirkland patio heater does not ignite. I have tried several times. Gas supply is good.
Read the directions carefully. Press and hold in the button for how many seconds to clear the line of air, press the ign switch while holding in the button. after a few moments, turn to the on position
Mar 03, 2013 | Heating & Cooling
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
My 2 year old PTH38PCP propane patio heater worked perfectly last winter. This year, every time I light it, it works for about 4 minutes and then shuts off. I have taken it apart and cleaned the...
is the pilot light making contact with the thermocouple, is the pilot nice and blue not yellow. some times tiny spiders get into the pilot tube when not in use (summer)
Dec 15, 2010 | Napoleon PTH38PCP Open Flame Gas Patio...
Have Endless Summer patio heater. I got the burner to run but after 3-5 minutes the heater shuts down. Also having problems getting the unit to fire after lighting pilot light Maybe thermo coupler?
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Oct 21, 2009 | Endless Summer 2009 Open Flame Patio...
Patio Heater won't stay lit?
The first possibility is a bad regulator, easy and cheap to replace. The second possibility is a bad thermocouple, and the third possibility is a blockage in the pilot assembly. The last two problems require you to take the head apart to replace the thermocouple or clear the blockage. If you are not comfortable taking the head apart, hire someone to do it.
Jun 14, 2009 | Endless Summer gwt501a Open Flame Patio...
Kirkland outdoor heater will not stay lit
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
Kirkland Patio Heater won't light
If the heater has been sitting for awhile, an insect or small spider may have set up house inside the gas controls and this needs to be cleaned out. The holes are tiny and doesn't take much to block. Try blowing out the orifices with a compressor.
Dec 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Williams 2509612 Ceramic Mid-Size Heater Logo
324 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
