Question about Nuvo NV-A4DS-DC SIMPLESE AUDIO DISTRIBUTION SYSTEM w/SPKRS System
NUVO Simplese - No sound out of one pair of speakers
I am not getting any sound out of one pair of my speakers on my NUVO system.
  • Anonymous Nov 29, 2007
    I am having the same issue, no sound out of one pair of speakers, all others work, and when the zoen is changed it works, nothing form zone one??
2 Suggested Answers
SOURCE:
  • 382 Answers
SOURCE: serial codes for nuvo simplese
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Posted on Jan 07, 2010
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
No power light at controller no lights at key pads
What is the solution?
I'm having the same issue.
Nuvo has been installed about 3 months.
Nov 11, 2012 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo Essentia low volume on left side speakers
check the wires make sure thay are not loose or partial connection
May 29, 2012 | Nuvo Essentia Amplifier
Nuvo Essentia system on/off button flashes when keypad is plugged in. I can get 1 port in the back of the EZ Port to work on all zones but when keypads are plugged into other ports on/off button just...
You may have a pair of the cat-5 wires in the incorrect order which is causing a combus fault. Check all your cat-5 connections, ensure they are T568a (GS/G/OS/B/BS/O/BrS/Br).
Let me know if that checks out and we will continue trouble shooting.
Thanks,
Oct 29, 2009 | Nuvo Essentia Amplifier
I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Light sound
Switch the speakers over just to make certain it's not the amp. If still bad on the good channel, then the crossover (inside) might have developed a fault.
Jan 25, 2009 | JBL E-30 Northridge E Series Bookshelf...
Serial codes for nuvo simplese
Cheers,
Nov 01, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Home Entertainment
It depends on what you want. Is your existing solution a surround sound system (You only mention a subwoofer, what other speakers do you have?)? Do you want full 5.1 or 7.1 surround sound? If you don't have this, and want it, your amp will have to be replaced, but your sub will fit in just fine. If you currently only have front left and right speakers, you will need to purchase a centre speaker and another pair (5.1) or two pairs (7.1) of speakers.
Sep 13, 2007 | Audio Players & Recorders
Nuvo NV-A4DS-DC SIMPLESE AUDIO DISTRIBUTION SYSTEM w/SPKRS System Logo
97 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
