Question about Photography
I push the rewind button and crank yet the film does not rewind. two seperate times the film came out of the canister. what am i doing wrong
I push the rewind button and crank yet the film does not rewind. two seperate times the film came out of the canister. hat am i doing wrong?
  • 571 Answers
Make sure to press the rewind button hard enough.
Posted on Aug 18, 2009
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
The Film advance lever wont move, the shutter button does nothing(i can push it down but nothing happens), and the button on the bottom is stuck in. In both cases this happened when there we no film in the...
Okay this is completely on memory. With the button on the bottom pushed in the camera is waiting for your to rewind the film back into the canister after this is done lift the wheel (not the crank it can break) the wheel is just below the crank and the back of the camera will open so you can take the film out. Reload a fresh roll close the door and advance to the first frame you are back in business again.
Jan 08, 2011 | Canon EOS-AE-1 35mm SLR Camera
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
My Canon AE-1 rewind crank came off while rewinding the film. can it be fixed?
Yes. I am not sure that you can do it yourself. It depends how handy you are with fiddly mechanical things. Any camera shop ought to be able to put it right.
I believe that you have simply unscrewed the crank by winding it in the wrong direction. It will screw back on, but you will need to open the camera to get hold of the internal part that it screws on to (the bit that fits into the film canister). This will need to be pushed upwards in its socket to allow you to get the crank started on the threads on the top of the shaft, and you will need to put the end of a screwdriver or something through the slot to get leverage when you come to tightening the crank the last bit.
If you heven't rewound the film yet, then open the camera in complete dark and rewind the film into the canister by hand. I usually do this in a darkened room under a bed quilt.
Nov 03, 2010 | Canon EOS-AE-1 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Minolta X300 camera
Hello
First thing to check with this is are we are talking about the correct part of the camera, the rewind lever on this model is on the left hand side (as you look through the camera), make sure you have raised the rewind crank arm (small plastic arm) out of the central knob, then looking on the bottom of the camera you should find a recess with a chrome button in it, push this button in, it releases the wind on mechanism, you should now be able to rewind the film using the crank, make sure you follow the direction of the arrow on the arm otherwise you will wind the film into the canister backwards, this will make it very stiff to wind and maybe scratch the film, plus you processor will not like you for this either.
Aug 16, 2008 | Photography
Big problem
The only thing i can suggest is pushing the film rewind button on the bottom of the camera body. crank the film back in to the canister and drop a new roll in. Ihave experianced this problem once or twice when I rolled canisters from bulk film and it would get jammed.
Good luck
Jul 06, 2008 | Nikon FM10 35mm SLR Camera
Photography Logo
519 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
