My unit is not being controlled by the themo, it just run
I need to make sure I have my wire connected . From the themo I have
red, green, white, yellow and blue. On the panel I have C Y GC . GH R W which color repesent C and GC and GH?
  • 116 Answers
Some are listed ac conventional and heat pump
how ever the r goes to red the blue to c for common the white to w for heat and the green to g for fan i guess strait air over electric heat due to no orange that would work the reversing valve on a heap pump hope this helps
Posted on May 31, 2009
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
My old thermostat has 8 wires, red, white, green, gray, black, orange, blue and yellow. I have the 44110 model need help connecting the wires
open unit and see what wires are running what never trust the colors.white heat'yellow cool'red 24v,green fan,blue prob your com,
Apr 17, 2012 | Heating & Cooling
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I have a RUUD AC Model UPFA 060JAS, Serial # 3687 F4787 3195. My dog ripped the wires apart on the outdoor unit. Wire coming out of the house (6) are colored red, blue, white, green brown, and yellow. ...
Paul, you will need to look at the indoor unit and determine which wires from outside are connected inside. let me know. more then likley they color coded it but better to be safe. also does the fan inside still run if you switch thermostat to fan ON. if not the transformer may have blown, if yes you need to make sure you shut the breaker controlling the inoor unit off while your messing with the wires, or you will blow the transformer in the furnace
Mac
Sep 26, 2009 | Heating & Cooling
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
I am attempting to replace an old bathroom exhaust fan with a Broan 680 fan/light. I am having a problem with the wiring. There are 2 wall switches for the light and fan. The existing wiring has red,...
The red and the black are the hot wires. One will be the fan and one is the light. The white is the 'common' for both fan and light.
It sounds like the new fixture has got one hot for both the light and fan, they will both run all the time from one switch. This is the blue wire. Hook it to the red or the black, which ever one comes from the switch you want to control it. Hook the white to the white on the new fixture.
The green is just a ground. hook it to the new fixture green or ground terminal. Cap or the black or the red that you don't use. It won't be need for the new one. The switch that it comes from will not control anything now.
Jul 25, 2009 | Broan-NuTone FAN CONTROL SWITCH
Red wire that is striped is hanging loose after removing filter
red wire common (hot) control voltage will control furnace and condensing unit red wire may be nothing if unit is running typical hook up red hot common green is fan yellow is cooling white is heat blue is usually neutral to transformer and to wire going to condensing unit red and white the freeze could be dirty coil, filter or both and possibly under charged.
Jun 16, 2009 | Coleman Mach 15 Air Conditioner
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Jun 10, 2007 | Casablanca Fan 3245T Ceiling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
