Question about Sony VAIO FX240 Notebook
LCD PROBLEM - KUBUNTU
I have an old SONY VAIO pcg-fx270 which is used for travelling purposes. I have installed KUBUNTU and have problem with LCD. Somehow I can't get the whole picture, just the inner square is presented. There must be some problems with the drivers or some specifics on sony LCD screen or something else ....
My notebook Sony Vaio PCG-4F6P can't connect to internet because Network Controller driver have lost. That driver lost after I upgrade from Windows XP to Windows 7 Ultimate. What should I do?
What happened to Windows 7 Support?
Downgrade to Windows XP until everything is ready to re install.
One of the joys of owning a Windows computer... Get used to it.
Can you upgrade to Windows 8?
Perhaps your Sony PC is just getting too Old.
Good Luck
Mar 03, 2015 | Sony Computers & Internet
Cant find drivers anywhere for Sony Vaio PCG-5A1M
http://www.downloadsarea.com/Free_sony-vaio-pcg-5a1m-drivers/
While I usually do driver downloads from CNet, this seems to be what you are looking for.
Apr 21, 2013 | Matsushita Sony Vaio PCG-5A1M 14.1in. SXGA...
Hi i need instructions on how to install a memory card in an old sony vaio pcg-f190 are ther any downloadable ? thanks
Hi astraspirit2. The Sony Vaio PCG-F190 uses 66MHz type memory and usually ships from Sony with 32/64MB of RAM. The Vaio PCG-F190 supports up to 192MB of RAM.
Most laptops have the memory compartment (at least the expansion socket or both) at the bottom. Flip the computer and you will see a little compartment (sometimes it even has a little chip logo). You will need a phillips #0 or #1 screwdriver. It's really simple, you insert the memory in the socket at an angle and then push it towards the laptop. I hope this helps.
Leo.
May 14, 2010 | Sony Computers & Internet
Vaio PCG-9S1L Screen is very dark, extremely hard , LAPTOP SONY
As stated in your post "two year old may have dropped it"
If this is true than the backlight has probably been damaged. The small flourescent tubes that generate light through the LCD display.
Email service@lanprotec.com for service options
Mar 01, 2010 | Sony Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Feb 02, 2009 | Sony VAIO PCG-K23 Notebook
Power adaptors/ travelling/ aptop
Yes, it is a switching power supply meaning that it automatically detects 120v (US) or 240v (EU) voltage. The only thing you might need is an adapter to convert the actual plug in from US to EU standards; they can be picked up for just a few dollars.
Thanks for using fixya and please take a moment to give this solution a rating of fixya. Thanks! :c)
Feb 02, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCG-FRV25 Cooling Fan Issue?
I was going to suggest overheating before I read your own diagnosis; Yes, sound like the fan, but you can check by opening up and watching it. Or install temperature monitoring software such as Speefan;
If it is the fan it may well be that there is only one possible replacement - officially. But it is usually possible to cannibalize something cheaper to suit your purpose!
Oct 25, 2008 | Sony VAIO FRV25 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO FX240 Notebook Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
