Question about Canon Office Equipment & Supplies
After firmware update control panel goes blank error light lit
Originally had issues printing pdf files - it was recommended to update the firmware - since my control panel screen goes black and error light is on.Canon ir3200
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Can you tell me how you updated the firware and who did it???
you need a special service tool to update a canon copier,
sounds like it has failed and needs re doing,
usually only canon techs have access to the service tool you need and the Firmware.
Posted on Jun 01, 2009
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
Good Luck
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
System error e225
Hello 3G,
or
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Canon imge class mf 4150 e225 eroor?
First:
Try to get the latest firmware at LINK.
Here is how to:
8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
Feb 23, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
First:
Here is how to:
49.2f9d error hp laserjet 3005dn how to solve the problem
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Dec 14, 2010 | HP LaserJet P3005 Printer
138 people viewed this question
old marine
old marine
