Question about ADIC Scalar i500 Tape Drive
HOW TO OPEN - ADIC Scalar i500 Tape Drive
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
If you open the I/O door, you can open the library door. You can then reach in and down. (The library door is next to the I/O drawer, where LCD screen is located. Opens on a hinge that is placed on the left of the door)
Posted on Nov 09, 2015
SOURCE:
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
Tip
Android Keyboard Shortcuts for Browsing Menu + I: Zoom in Menu + O: Zoom out...
<br />Android Keyboard Shortcuts for Browsing<br /><br />Menu + I: Zoom in<br /><br />Menu + O: Zoom out<br /><br />Menu + J: Go back a page<br /><br />Menu + K: Go forward a page<br /><br />Menu + R: Refresh current page<br /><br />Menu + F: Find on page<br /><br />Menu + B: Open bookmarks<br /><br />Menu + S: Open social network sharing menu<br /><br />Menu + H: View browsing history<br /><br />Menu + S: Open browser settings<br /><br /><br /><br />Android Keyboard Shortcuts for Apps<br /><br />Search + B: Open browser<br /><br />Search + C: Open contacts<br /><br />Search + E: Open e-mail<br /><br />Search + G: Open Gmail<br /><br />Search + I: Open calendar<br /><br />Search + M: Open maps<br /><br />Search + P: Open music<br /><br />Search + S: Open text messaging<br /><br />Search + Y: Open YouTube<br /><br />
on Feb 06, 2011 | Google Android
I want open new 2go account
I Want to open mew 2go account
Jul 06, 2011 | Mobile Roadie iPhone Apps
I cant' open the facebook homepage
If you can access other websites aside from this follow these steps:
1. Open Control Panel, then Internet Options, then open General tab and delete browsing history.
2. Open again, www.facebook.com.
3. If it won't open still. Check if you have proxy, if there is, remove it.
4. Open again, www.facebook.com.
5. If it won't open still. Reset your browser, Open Control Panel, then Internet Options, then open Advanced tab and press the reset button.
Try open facebook again.
Mar 18, 2011 | Computers & Internet
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
Quantum Atlas V p/n XC18L011 18.3L trying to address drive correctly. Between the scsi and power connections there is J1. The drive label does not not refer to it. Drive came inb with one jumper...
Each SCSI device must be assigned an ID, either from 0 to 7, or from 0 to 15.
So, typically, you have 3 or 4 pairs of pins, to create the various IDs:
zero - open, open, open
one - open, open, short
two - open, short, open
three - open, short, short
four - short, open, open
five - short, open, short
six - short, short, open
seven - short, short, short
by using one or two or three jumpers.
If you only see one pair of pins, you've got some other function to enable/disable.
Assume that the "factory" setting for that jumper is the "optimal" setting, and leave it alone.
Nov 02, 2010 | Quantum Atlas V 18 GB SCSI Hard Drive
Can u help us m8
contact the dealer of where you bought your stereo...or maybe the sony company...:)
Dec 13, 2007 | Sony CDX-M610 CD Player
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Oct 18, 2007 | Sony CDX-M630 CD Player
ADIC Scalar i500 Tape Drive Logo
589 people viewed this question
Top ADIC Computers & Internet Experts
Alun Cox
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
