Question about Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio
Won't start 03 rigmaster apu has "safty door open" on monitor and won't even try to start. leon
    Problem Solver:
  • 7 Answers
Sounds like your units cover safty switch has failed. the unit thinks the door(cover) is open(off) If you can find the switch you should be able to bypass by just shorting the wires together
Posted on Aug 03, 2009
Switch on the door is broken, is this a safty switch?
It lets the machine know the door is closed so it is OK to start.
Jump the switch out and the machine will start even if the door is Open. no biggy.
Dec 02, 2013 | Dryers
Gas dryer wont light with door closed
Check the exhaust to make sure that it is not clogged.
Jul 07, 2013 | Maytag Atlantis MDE7400AY Electric Dryer
Monitor starts and stops by himself when I install the videocard driver
Try reinstalling the Catalyst drivers. Something might've gone wrong with your last install.
Feb 21, 2013 | Advanced Micro Devices AMD A4-5300 APU...
Escalade 03 courticy lights won't come on when door is opened
Next to the head light switch you should have a roll dial switch and a round over-ride button push this once and overhead courtesy light goes on/off push twice and it over-rides headlights sensor to turn on/off
Sep 19, 2012 | 2004 Chevrolet Tahoe
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
Dec 05, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
Apu starts fine but no fan no heat and no air conditioning and no 120 volt.
Hi there, Would this be a preheat / comfort pro APU? If so I would start with removing the top cover on the APU. There will be a fuse holder with a 20 amp fuse on the back wall on the left side of the APU above the APU controller. Check and see if the fuse is blown. If it's not then the CCU board under the bunk/ bed isn't seeing power. Either 12v harness or the communication harness both from the APU controller to the CCU board are rubbed on the frame, or the CCU board isn't transferring power properly. The CCU board is under the bunk. There are 4 3/4 bolt's that hold the lid on. Start the APU and look at the board you should have green light's light up. these light's are called input light's. Then chose a function on the driver control panel as in heat, a/c, low or high fan and see if they come on. If the driver control pane are showing the function on look down at the CCU board and see if there are orange light's on. these light's would be your output light's. There's a lot of cause's for this problem if you need further help feel free to ask. Thank's
Nov 08, 2010 | Carrier Heating & Cooling
Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Aug 07, 2009 | Microwave Ovens
Load rigmaster apu
Try running the exhaust in to the truck cxhaust pipe. Have a carrier that way and it quietened the exhaust noises. The fitting can be got from the dealer.
Apr 26, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
03 Tribute sat for 6 months
There was a opening for a key on the driver's door handle, so I got into the car that way. Ha, haven't tried to start it yet!
Jan 26, 2009 | 2003 Mazda Tribute
Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio Logo
155 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
