Question about Apex Digital AT2008 20" TV
NO PICTURE OR SOUND
THE TV SENSOR TURN ON AND OFF THE TV IS ON BUT NO SOUND OR PICTURE IT POP ON 30 MINUTES LATER I just got a tv from my mother and it was working fine, but when i hooked it up in my room, it just turned black. no picture or sound. but a funny thing is the channel display and options still work. weird, huh? if you can answer this, please do. thanks.
  • 378 Answers
It seem that the OSD still working but the screen is black. try to resolder it first because many old tv has cold solder problems.
Posted on Jun 01, 2009
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
I have an hlp4663w 46in dlp samsung. The problem is after turning on the set it runs for a few minutes and I loose the picture, but I still have sound. I can turn it off and then back on and the picture...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
JVC AV-32F476 on timer green no picture no sound
Power supply failure, expect to pay $100-150. worth the investment JVC made some good tvs Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | JVC AV-32F476 32 in. Television
NO PICTURE OR SOUND
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
May 29, 2009 | TruTech PLV16320 Television
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Rear Projection Blurry Picture/Popping Sounds
Might be a bad CRT, might be a bad focus block, I would refer you to a Repairman as it will take some experience to repair.
Jul 10, 2007 | RCA P52921 52" Rear Projection Television
Apex Digital AT2008 20" TV Logo
171 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
