Question about Maytag Washing Machines
Washer won't spin out the water
Waher won't spin out the water
  • 6,784 Answers
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on May 31, 2009
My ge waher wont spin or rinse model number wwre5240d1ww
Check the water valve screens in the water valve. Remove and clean
Jan 11, 2014 | GE WBSR3140DW Top Load Washer
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
Washer wont spin
If your waher drains but won't go into the spin cycle, then it is most likely the transmission. BUT make sure that you check it in all the different wash modes, since if it works in one of them then it would change the diagnosis.
Jul 30, 2011 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore #110.26954690 won't spin in spin cycle
If it doesn't pump out water either, yes, first, I would suspect a broken belt (or motor coupling if direct drive).
Unlikely that the center cone is jammed.
Charlie
Aug 23, 2009 | Kenmore 22422 Top Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Spin problem
you probably have a partial clog in your pump not allowing all the water to drain out the first time.id check the pump first
Jan 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Waher wont spin
first, if it's under warranty, have them service it, if not then....
the maytags work mainly on belts with a forward and reverse on the motor. forward washes, reverse drains and starts spin cycle. if the motor does reverse and drains the water, then it's probably the transmission of the washer. these washers have 10 years parts on the transmission, so I would have a service repairman come out and fix it. you'd only pay for the labor and the transmission would be free.
Jun 21, 2008 | Maytag SAV2655A Top Load Washer
Washing Machines Logo
194 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
