Question about Sony Playstation 3 (PS3) Console
Ps3 shuts off on its own
Red flash on stanby,then push the on/off too start playing and shutsdown automatically and the blinking red light Well the first thing, i went to turn on my ps3, and the red light was not on. (had to turn power supply off then back on.) Then it would fire up, run for a while, then just shut off. its been doing this for a day and a half.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 64 Answers
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. A corrupted file is about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck.
Posted on May 31, 2009
2 Suggested Answers
  • 265 Answers
SOURCE: turn the ps3 whait for too start and dosent
Hi There,
I have had this problem, as my PS3 is now out of warrenty i have decided to fix it myself, so if your PS3 is out of warrenty aswel i sugguest you do the following, if not then send it back to sony.
The problem seems to be a over heating, you will notice this as the fan kicks in to high power after about 10mins.
What you need to do is disassemble it, heres a guide that can help you: http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm.
After this you will see the CPU and GPU, the problem there is the thermal compound on it, its dry and cracked and not enough, u need to clean all this off and buy some Artic Silver 5 Compound, on ebay for under £5, you then need to place some on the CPU and GPU corner to corner then smooth it across with a card, as thin as you can! then put it all back together.
problem solved
Posted on Feb 16, 2009
I have the 40 gig ps3 console. Today, I was in the middle of a game (it had only been turned on for about 20 minutes) when my console shut down and the red light started flashing. I turned it off and let...
Hello there Rick
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Sep 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 stopped suddenly working and red light blinking push the on/off button the light stops blinking and stays fix red push again turns green few second then red blinking again any idea what may have...
Hi Andrea.
What your experiencing is the the well known "PS3 Red/Green Light of death" which generally means a hardware failure or overheating. If it's overheating (2 Red lights) then it will automatically shut down after a while but from what your saying it's not overheating.
If you have it in warranty you have to send it to Microsoft and they will send it back usually 3-4 weeks or take it to a reputable gaming console repair shop (this will cost money).
But first check that your AV cable is properly plugged in (in this case all four RED lights are bleeping). If you're using an HDMI connection forget about this step.
So if you don't have a warranty then it will cost you about $150.
Another thing you can do is follow a guide and repair all of the errors with the PS3 including your problem. Click here for more information.
May 19, 2011 | Sony Playstation 3 (PS3) Console
My console dont play when i turn on red light flash and turn off and dont play
Sounds like Yellow Light Of Death. When it shuts off before the red light starts blinking is their a yellow light that blinks for less than a 1/2 a second? If not let me know and we can do a chat to figure out the problem. If it does then here is a link for my step-by-step instructions on how to fix it.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
Ps3 shut down wont restart flasing red light
PS3 shut down automatically and leave a flashing red light,
Please read this post, you can find a solution : PS3 Red Light Blinking Fix
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
How do i fix flashing red light problem?
If its a little red light that flashes when ur ps3 is turned on thats your controllers connection light it might mean your controller still conected to the ps3
Jun 04, 2009 | Sony Video Game Consoles & Games
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Turn the ps3 whait for too start and dosent
Hi There,
problem solved
Feb 16, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,338 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
