Question about Honeywell Programmable Thermostat Heater
Honeywell RTH2310 heating while it's supposed to be cooling
I recently replaced a 3yr old Honeywell thermostat with the new programmable RTH2310.
When I connected it, the heat came on when it is in cooling mode. I connected all of the wires as instructed. I had taken a picture of the wiring on the old one just to make sure. I live in Florida and have an electric heat pump. I set the back jumper to electric mode. The jumper between Rh and Rc is still in place. Is this the problem?
The old thermostat was wired with the red unconnected but the brown wire was connected to R. I repeated this condition on the new one.
The Orange, Red, Blue, and Black wires are taped off and unconnected.
We had experienced the same problem with the old thermostat but it was infrequent and barely noticable. It appeared that both cooling and heat were running concurrently. Now it is just heating.
Help!!
  • 116 Answers
Ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
Posted on May 31, 2009
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
The filter needs to be replaced on my RTH2310. Where is this filter and how do I replace it? Libby
No the tstat just has a reminder to replace you system stat. There should be a rest for it. And the filter should be in the air handler/Furnace
Aug 28, 2010 | Honeywell Electronic Programmable...
Only have two wires on old thermostat,where do i hook them up on a rth2310 thermostat
More information would help but I believe that you are trying to hook up a programmable thermostat to your old heating system which is what? Oil forced air, heat pump, gas? Give me more info and I think that I can help you.
hardrocko
Feb 07, 2010 | Honeywell Electronic Programmable...
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
New rth2310 themostat does not blow cool air
I don't believe you're going to get the new one to work -- sounds like it doesn't have enough control wires to operate your HVAC system. If it is designed to operate a 7-wire system, the documentation should show how to hook the 4-wire tstat so it will work.
Apr 21, 2009 | Honeywell Focus 6300B 5-2 Days...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
558 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
