Question about Brother XL-2600
Please help me resolve this issue
I have a brother xl2600 and my bottom stitches are loose and have loops in them how can i solve this problem
  • 23 Answers
This sounds like you have not threaded the bobbin properly.
Posted on Apr 13, 2010
Brother industrial sewing machine bottom stitch slack
Please describe further what you are seeing on the seam? Loops on bottom? Loops on top?
Dec 29, 2012 | Sewing Machines
My top stich is tight but my buttom is loose on my brother sewing machine
if the bobbin stitch is loose tighten the top thread tension one number at a time & sew alittle bit & if it's still loose tighten it one more number till you get the correct stitch
Feb 10, 2012 | Brother XL2600 Mechanical Sewing Machine
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
I live in South Africa and have a Brother Innovis 90E embroidery machine. I have a problem with the tension in that the top thread loops at the bottom of the picture I am embroidering. In addition, the...
Lauren, were you able to solve your problem. I have the exact same machine and am experiencing the same problems that you state.
Kind regards,
Chantell
Aug 15, 2010 | Brother Sewing Machines
How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Jun 13, 2009 | Brother XL-2600
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Loose stitch with loops on top of material i got the right needle and bobbins what do i need to do i have ls 2125 brother
General rule of thumb is this.. If it loops on the bottom the problem is on the top..
If it loops on the top, the problem is on the bottom.
Sounds like #1 your bobbin is wound very loosely , #2 your bobbin thread has to go thru its tensioner.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bottom thread is very very loose during stitching, looped up
Looping on bottom:
Great description, that helps a lot. Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Kent581
Mar 03, 2009 | Husqvarna Viking 1
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Brother XL-2600 Logo
142 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
