Question about Tools & Hardware - Others
Gun wont drive nails in home all the way
Not fuuly fixing nails
  • David Ford
    David Ford May 11, 2010
    What is the brand and model number we are talking about and I will see if I can help
  • Dean
    Dean May 11, 2010
    I assume you have tried adjusting the driving depth of the nail on the nail gun and are operating it with the correct pressure of compressed air?
  • 142 Answers
If your talking about setting the nails all of the way, make sure the gun is lubricated with oil in the air input as well as making sure the track is lubed as well as wd40 in the nose
Posted on Jul 21, 2009
Nail gun 58-8434-4 will not drive 3" nails all the
Hi foxden503,
Welcome to fixya!
As a general rule, framing nailers use anywhere from 45 to 120 psi to drive nails. But this also depends on the hardness of the wood.
The nail head should be flush with the surface. If it sticks above the wood, increase the pressure a little bit at a time until you achieve this goal.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 20, 2011 | Tools & Hardware - Others
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
My paslode nail gun needs to be cleaned
Use the Paslode cleaning spray (Lowes and home depot stock this)
Detailed instructions can be downloaded from the paslode site. http://www.paslode.com/owners-manuals.html
Jun 24, 2009 | RTO Paslode #650027 2500CT Placement Nail
Air leaking out of trigger and drive pin wont recoil it will shoot one nail then drive pin wont go back you have to unhook airline and manually push pin back.
To fix this problem you will have to disassemble the gun to get at the trigger area. Look for a broken "O"-ring. This is probably jamming the recoil of the drive pin.
Jun 04, 2009 | Stanley Bostitch F21PL Nailer
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Sep 01, 2008 | Makita Brad Nailer Finish Nailer...
Nail Gun cost
Aug 27, 2008 | Bosch 18V Cordless Planer 53518
Nail Guns costs
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Tools & Hardware - Others Logo
170 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
