Question about Maytag MSD2656G Side by Side Refrigerator
Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
  • 3 Answers
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
Posted on May 31, 2009
Drain pan fills up and overflows onto floor
Is the pan "level" under fridge? If not, it will not hold the amount of drainage that is put out and spill onto the floor.
Mar 07, 2015 | Refrigerators
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
Why is my drain pain overflowing?
on most fridges, you should be able to empty drain pan. Remove grill on bottom at the floor, and see if pan will slide out. Good-Day!
Jul 26, 2014 | Roper Refrigerators
Kitchen Aid refrigerator freezer (freezer on bottom, which is a pull out drawer), water is filling the compartment on the bottom of the freezer, when it is full, (usually once a week) it will overflow onto...
If You Have a ice maker the water inlet (electric valve) on back of
the refrigerator is probably sticking slightly open. Or the drain to the pan in the freezer is stopped up.
Jan 02, 2018 | Whirlpool GD5SHAX Side by Side...
The drain pan at the bottom of the freezer side is overflowing.
If your water filter is " thru the kick plate , at the bottom , replace the filter . I have found several times now , where the filter rubber seals , have leaked into the drain pan , causing it to over flow . You do not have to replace the filter housing , just the filter .
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Defrost pan keeps overflowing
On the freezer side at the bottom of the freezer coil there is a drain. There should be a thin aluminium filiament attached to the defrost element and feeding down into the drain tube. This filiament conducts heat from the element down the tube preventing ice forming in the tube and keeping it clear.
Mar 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Feb 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag MSD2656G Side by Side Refrigerator Logo
782 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
