Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to make the ice maker work on my whirlpool side x side refrigator there is a bar above the ice box dispenser should it be up or down?
Where the ice box is there is a bar should the bar be up or down to make ice
  • shelbybernar May 31, 2009
    Thanks so much it kind of made sense to me that the bar would be down but I wasnt sure. Once again thanks bud
  • 1,305 Answers
When the bar is up...it's off..
it's a sensor that will lift up as the ice tray gets full... otherwise you might have a freezer full of cubes!
So if it's up, it's off...
Cooooooool huh?
Sorry for the pun... but it's Sunday!
K
Posted on May 31, 2009
Ice maker not working since i moved refrig
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fs45
Aug 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not rotating
i had the same problem ,... didnt work for a month ... then i got pissed so i just messed around with it .... i found a bar hanging above the ice carton ... make sure ur ice cartn is positioned right and pull the bar down and make the little stick hanging off of it sit on down ..(put it down)
Jul 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool refrig water dispenser and ice maker stopped working
It sounds like the filkter may be plugged up or frozen. check the outlet of the filter to see if the water is going thru. Good Luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not comming to ice maker
Ice maker is fixed. We unpluged the frig for about 10 minutes and it is now working. Someone else was given this as a solution from FixYa and it worked for me. Thanks
Nov 22, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
130 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
