1) Loose bearing/bushing in distributor body. (The shaft that the rotor screws down to, goes through a bearing, or bushing, in the distributor casting)
See if you get excessive axial run-out of this shaft, by trying to move the rotor side to side, (Front to Rear, also)
.005 deviation is too loose, (Five thousandths) If you can feel, or see any perceptible movement, side to side, it is too much.
2) What spark plugs are you running? Split Fire, or similar, can put too much resistance back to the rotor button. This can burn it. (Can also burn holes in your pistons eventually)
Good day, Before proceeding there are a lot of buttons and cover emblems that cover screw holes. Remove by prying off with a small screw driver as needed. As well, remove all food etc. As well, keep track of all bushing and shims holding the door hinges in place.
1. With the top door closed, remove the top bracket. Open the door with both hands, open approx. 1 foot and lift off. 2. Remove the middle bracket, and remove bottom door as in step one. 3. Remove and reinstall handles on the opposite side of each door. 4. The bottom support bracket must be removed, and remounted on the opposite side, with the pin sticking up. 5. Reinstall in reverse order using bushing and shims as needed to assure correct alignment.
hi cody
im dave
the problem with your car is right there on the front of the hood. It is a little red and silver emblem that says "Saturn"
Saturn has had numerous consumer complaints relating to their crappy trannys and will do nothing to help consumers.
there is a plastic bushing on the shift linkage that is prone to breaking and saturn will not sell the part without the whole shift linkage kit at a cost of a few hundred dollars. there is however an individual selling the bushing on ebay. try http://cgi.ebay.com/ebaymotors/saturn-shifter-
hope this helps because GM/Saturn wont.they will tell you you need a whole new transmission at a cost of $6000.
Emblems
Unlockable
How to Unlock
Amy Emblem
Complete Mission mode with Amy
Aquatics Champs Emblem
Gold Medals in All Aqautics Events
Blaze Emblem
Complete Mission mode with Blaze
Bouncing Emblem
Perfect 10 on Trampoline
Bowser Emblem
Complete Mission mode with Bowser
Sonic Emblem
Complete Mission mode with Sonic.
Shadow Emblem
Complete Mission mode with Shadow.
Knuckles Emblem
Complete Mission mode with Knuckles.
Luigi Emblem
Complete Mission mode with Luigi.
Waluigi Emblem
Complete Mission mode with Waluigi.
Mario Emblem
Complete Mission mode with Mario.
Wario Emblem
Complete Mission mode with Wario
Vector Emblem
Complete Mission mode with Vector
Yoshi Emblem
Complete Mission mode with Yoshi
Tails Emblem
Finish mission mode with Tails
Olympic Record Emblem
Achieve an Olympic Record the very first time you compete in an event
World Record Emblem
Achieve a World Record the very first time you compete in an event
Network Emblem
Connect to the Nintendo WiFi Connection
Rocket Emblem
Peform a successful starting dash in a track event
Penalty Emblem
Commit a foul in an event
Peach Emblem
Complete Mission mode with Peach
Daisy Emblem
Complete Mission mode with Daisy
Field Emblem
Received after earning gold medals in all field events.
Aquatics Emblem
Received after earning gold medals in all aquatics events.
Gymnastics Emblem
Received after earning gold medals in all gymnastics events.
Dream Emblem
Received after earning gold medals in all dream events.
Fencing Emblem
Received after winning fencing match without losing any point.
Archery Emblem
Received after scoreing 120 points in archery event.
Shooting Emblem
Received after scoreing 40 points in shooting event
Full Play Emblem
Received for playing all events.
Table Tennis Emblem
Received for winning 5-0 in Table Tennis.
Gallery Owner Emblem
Unlock the entire gallery.
Collaboration Emblem
Play at least one event with all characters
Crowns
Unlockable
How to Unlock
Mario Crown
Get all gold and 1st medals using "Mario"
Daisy Crown
Get all gold and 1st medals using "Daisy"
Luigi Crown
Get all gold and 1st medals using "Luigi"
Peach Crown
Get all gold and 1st medals using "Peach"
Bowser Crown
Get all gold and 1st medals using "Bowser"
Vector Crown
Get all gold and 1st medals using "Vector"
Sonic Crown
Get all gold and 1st medals using "Sonic"
Shadow Crown
Get all gold and 1st medals using "Shadow"
Amy Crown
Get all gold and 1st medals using "Amy"
Blaze Crown
Get all gold and 1st medals using "Blaze"
Knuckles Crown
Get all gold and 1st medals using "Knuckles"
Waluigi Crown
Get all gold and 1st medals using "Waluigi"
Wario Crown
Get all gold and 1st medals using "Wario"
Dr. Eggman Crown
Get all gold and 1st medals using "Dr. Eggman"
Tails Crown
Get all gold and 1st medals using "Tails"
Yoshi Crown
Get all gold and 1st medals using "Yoshi"
Complete Crown
Get all gold and 1st medals using every characters.
Unlock Unlock Mario and Sonic Tunes
Complete all 5 of the levels of the minigames found in any of the 5 doors in the Gallery. Complete all minigames and all their levels in each door to unlock all of the music available for the Gallery's Jukebox.
Unlockable
How to Unlock
One Mario and one Sonic music track.
Complete each of the 5 levels of minigames in any of the 5 doors found in the Gallery.
say thanks
The Underwriter Laboratories of Canada are an offshoot of the Underwriters Labs of the U.S. They test consumer products for safety. The Procom space heater is advertised as a vent free heater fired with propane. As it is vent free I doubt you can convert it into a vent type appliance. When propane burns, it produces carbon dioxide and water vapor. It must be used with adequate ventilation for combustion. It consumes oxygen to burn. If burning it without ventilation it lowers the amount of oxygen in your room creating a hazard to human life. this is what kills. Perhaps the ULC standards are more stringent then the US but I suppose if the unit has the United States UL emblem, using it in Canada, you may need a direction from your local extension service before you can use it.
