Question about Frigidaire Washing Machines
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
My Frigidaire front load washer model number FWT645RHS1 won't fill with water. The water goes into the tub but just drains and doesnt stay in the tub. it also wont spin properly. Whats wrong with it? Can I fix it myself? Is it a Timer Problem? Is it electrically Timed on this model? Im very very confused searched every where for answers.
  • babe_kins Jun 01, 2009
    The drain hose is Over three feet up.
    I was playing around with it tonight again... it will spin.. the wash cycle absolutely will not come on though. Any suggestions?
  • Anonymous Mar 16, 2014
    wont spin but fills
  • 6,784 Answers
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on May 31, 2009
  • Michael Masters
    Michael Masters May 31, 2009
    Concerning the improper spinning, this could be an issue concerning the motor control board. if the improper spinning continues, replace the motor control board.
Lights come on, door is closed, light load, but door will not lock so machine can begin filling with water. LFT7000ESO MODEL.
Good Afternoon Friend,
I understand that that you are having trouble with your Frigidaire washer, model# LFT7000ES0, and the door will not lock and begin filling with water. The model number you have provided, comes up as an invalid number. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If you do need more assistance, I will please ask for the model number of your washer. Typically you should be able to find this located inside your appliance around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Front load frigidaire washer wont do anything but fill with water and drain and the door wont lock
Hello Cheryl Watson - Not quite sure I understand the issue. If the unit is filling with water and draining immediately, with no tub rotation or movement, more than likely there is a failure with the motor circuit (i.e. the motor, motor control board, belt, wiring or door switch). Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 04, 2013 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
I leave the door open on my front load washer so it can dry and not have a smell. Twice now I have came home to a flooded house. The machine apparently starts to fill with water on it's own and all the...
Turn off the water at the Fill vale if it now does not fill fit a new Solonoid valve to the fill on the machine...if it still fills with the water turned off then the problem is with the drain Too Low allowing water from the sink to enter machine.....
Feb 10, 2011 | Frigidaire ATF6000ES Front Load Washer
How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Apr 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Isn't Filling Properly.
How old is this washer? You maybe looking at a defective fill valve (where the hoses on the back connect to), or an obstruction in the pressure hose that leads from the Load Size selector to the fill valve. Also, unplug the unit and check the electric connections on the valve as well as the Load Size selector.
Dec 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
458 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
