Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Overheated Minn Kota Endura28
My Minn Kota Endura 28 overheated after 90 mins on the lake and a puff of smoke was noticed. The cables from the battery fused together from the heat.Do I simply need to replace the switch and cables or is there something more complex to be repaired? Thanks
    Problem Solver:
  • 10 Answers
This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
Posted on May 31, 2009
My minn kota endura 55 is three years old is making a grinding noise when in operation..
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
What spec battery is the best for the Minn Kota 40 Endura trolling motor?
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
May 19, 2011 | Minn Kota Endura 40 Transom Mount Trolling...
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
How do i extend my battery cable on my minn kota 36 endura
You can purchase a battery extender cable. Depending on how far you need to go, you can buy them in various lengths. I've done the same and bought a 15' extension (always buy a few more feet than you think you need). Many places carry this. I bought mine at BassProShops for $25.00 and it comes with fuses which help to make sure you never fry your motor or battery!
Aug 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
558 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
