Question about Whirlpool Calypso GVW9959K Top Load Washer
Front load CAH4204AWJ
My washer runs constantly. Once it gets down to the last minute, it starts the cycle over again. I have to manually turn the washer off and unplug it to turn it off and unlock the door. Is there a way to reset the washer or something? Sometimes my washer even stops in the middle of a cycle and does nothing. Again, I ahve to manually turn it off and uplug it to turn it off and unlock the door. It's really inconvenient to have to sit and watch it to make sure it doesn't run all day.
  • lilkathy106 Feb 21, 2010
    So what does that mean, and how do I fix it?
  • 3,741 Answers
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
--------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 22, 2010
  • 1,531 Answers
It seems that you have a malfunctioning control board.
Posted on Feb 21, 2010
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Water leak from bottom of washer
Hello, With the lack of information I will assume this washer is a top load. The most common cause for a leak on a kenmore washer is the pump. The pump is mounted directly onto the motor and is attached by 2 clips. Lean the machine back so you have access to underneath the machine, remove the 2 drain lines attached to the pump and the 2 clips holding the pump onto the motor...examine the point where the pump hooks up to your motor and you should find evidence or water leaking at this point. Replace the pump :) If you have any other question or concerns please feel free to comment again. Good Luck!! Mike
Sep 09, 2009 | Washing Machines
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
HE3 front-loading automatic washer
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
Aug 28, 2008 | Washing Machines
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
