Question about Poulan Garden
Will not run unless half choked.Will not run above idle speed.
Will only start when Fully choked.Will not accelerate above ide.
  • 376 Answers
It is a carburetor problem. The easiest thing to do is replace the carb. If you can do that yourself, post the model # of the blower and I'll tell you the part # of the carb. Otherwise, you will have to take it to a shop
Posted on May 31, 2009
Cold choke baffle has 3/16 opening minute I pump accelerator choke thermostat closes primary baffle shut no air to start I force choke open to start why insufficient air to run at high idle?
Your engine probably has an automatic choke device that adjusts automatically with engine temperature. To set the choke when the engine is cold you have to depress the accelerator to the floor and release it completely. You shouldn't have to depress the accelerator again to start the engine, turn the key the engine should start. As the engine begins to warm up it will also begin to initially run faster then it will start to run rough. At this point you have to press the accelerator and release it again. The auto choke mechanism should allow the choke butterfly to open. There may be a number of stops in the system and the choke butterfly will stop again still not fully open and only become fully open when the engine is at operating temperature. Hope this answers you question, Rgs. Bob
Jun 21, 2015 | Cars & Trucks
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Will start with some amonut of choke on, but will ...
Carby carby carby!
Give the carby a flush with some Carby Cleaner. (retail 400g aerosol can)
Check condition and clamping of inlet manifold for cracks, warping or air leaks.
Reset Slide Needle one notch down.
Turn air mixture screw fully in and back out one and one half turns and try idling now.
When you get engine idling turn the air mixture screw in or out to the highest revs without use of throttle. Reset idle to optimum speed with throttle stop or idle screw.
Cheers.
May 19, 2010 | 2001 Yamaha SR 125
1984 passat cl. the automatic choke runs too fast
the choke has 3 screws to adjust the unit,the choke itself will normaly be siezed inside at the age.With a warm engine, loosen the 3 screws and turn the choke untill the idle drops.
or as i did it-with a cold engine, remove the airffilter and with the 3 screws loose on the choke press the accelerator pedal just over half so the choke is engaged and the looking inside the filter housing adjust the choke flap by turning the choke housing until the flap is 3/4 closed and tighten slightly and start the car.Do remember to check your distributor timing whith a warm engine and make sure the sparkplugs and airfilter are okay as each upsets the other.
Mar 06, 2010 | 1990 Volkswagen Passat
1985 dodge ramcharger, carburetor issues
Sounds like a problem I had with my '85 Dodge D150 Ram Prospector. In my case, the automatic choke was broken and it was starved for air during acceleration because the choke was always closed. It ran fine at idle or very slow acceleration. I wired the choke open and it runs much better, although it is much more difficult to start as the fuel mix is lean due to the extra air. Once it gets warmed up, though, it runs fine. I hear that the barrel carb on mine often has problems.
Jan 29, 2010 | 1985 Dodge Ramcharger
Engine stalls after acceleration - Start fine, idles fine, but won't run at full speed. Engine dies when throttle is engaged more than half-way. Fuel filter is ok, air filter has been cleaned.
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
Oct 04, 2009 | Echo Garden
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
685 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
