Question about Honeywell Programmable Thermostat Heater
My thermostat quit working
Honeywell TH8110U - 4 or 5 years old, worked fine until today.  i noticed it was displaying the wrong indoor temp for awhile this morning.  now it displays no temp at all and nothing works.  will not heat or cool.  when i select one of the functions on the display it just turns itself off.  clock works.  correct day displayed.  i can turn the fan on, but that's it.  is the thermostat fried or something?
  • oingoboingo2 Jun 01, 2009
    well, it's a hard-wired thermostat, although it has batteries for back-up. i figured the batteries were okay, because each time i've pulled the faceplate off, the clock keeps working.  also, there's been no low battery warning.  thanks for taking the time to reply to my problem.
  • oingoboingo2 Jun 02, 2009
    thank you for your reply.  i changed out the batteries tonight, just to be sure, but it made no difference.  i bought a new honeywell thermostat at home depot today and i think i'll try installing it tomorrow.  thanks again...i'll let you know what happens.
    Scholar:
  • 79 Answers
I work alot with the Honeywell thermostats and in the past couple of years I have seen the Vision Pro thermostats have some fail issues. There is a 5 year warranty on these thermostats so you should'nt have to pay for a new one if it's under 5 years old.
Posted on Nov 20, 2009
    President:
  • 3,433 Answers
Does it have batteries that need replacig. I think so. good luck.
Posted on Jun 01, 2009
  • 1 more comment
  • Ned C Cook
    Ned C Cook Jun 02, 2009
    No response , Yes, I would address the thermostat. I've changed mine 4 times in 30 years, with the best each time. My new stat just had to be replaced after only 7 months in service.. good luck and if you need, I'll watch for you. Here to help.
  • Ned C Cook
    Electronics take very little power so change out the batteries just to make sure. - There may be enough for the display but not to drive the thermostat. That would explain the display changes.
  • Ned C Cook
    thanks and good luck
2 Suggested Answers
  • 571 Answers
SOURCE: round honeywell thermostat
Sounds like you have a T86 thermostat...take the round front cover off to view the Mercury switch. Watch the bulb when you change the temperature to a higher setpoint. If the bulb makes contact when rotating it up, and the furnace doesn't go into a call for heat, then it could be the thermostat, wiring, or furnace problem.
Posted on Dec 15, 2013
Honeywell rth7400d
your thermostat is getting bad and cannot get temp very well either due to batteries or old life try getting a new one
Dec 17, 2013 | Heating & Cooling
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
No power
check transformer in furnace... thermostats get there power from it....not the room its in
Mar 15, 2009 | Honeywell Electronic Programmable...
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
980 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
