Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Where is part number 283p144080 on my tv
Wher is part number 283p144080 on my mitsubishi ws-65315 tv
Www.free-service-manuals.com
Posted on Jun 04, 2009
Can I hook my laptop to my WS-65315 TV
I do not see any way unless you can outfit a connection to one of the rear inputs---this set was never designed for this type of use so aspect if connected would likely not be useable.
Nov 03, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
User manual for mitsubishi TV model ws65315
here it is :
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55315.pdf
SD TECH
Oct 31, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS 65315 65" Projection TV
I'm not sure if this is the initial price but it was $2199.99 at Best Buy when I purchased mine on 10/01/04. Hope this helps! -D
May 14, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
