Was having problem with cooling fan on TV but blew dust off it and now it seems to be working fine. Can only see 1 fan. Is there more? Thanks
Comments:
Jun 01, 2009
- THANKS SO MUCH FOR THE REPLY. THE ONE I WAS HAVING TROUBLE WITH WAS THE SMALL FAN YOU CAN SEE.THE FAN WAS NOT RUNNING AND I WAS GETTING THE POWER LIGHT FLASHING 4 TIMES. BLEW THE DUST OFF THE FAN AND NOW THE TV IS WORKING FINE. THANKS AGAIN.
There are either 3 or 4 fans in your set. Lamp, digital board, chassis, and sometimes ballast. The small fan you can see from the back of the set is normally the one causing trouble. If it develops a bad pole in the fan motor it will sometimes not start. If your set fails to turn on, look at the fan and see if it is running or not.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony KDS-50A2000 50 in. HDTV
I tried a new lamp. That did nothing. I tried all kind of different settings and that did nothing....
(More)
I tried a new lamp. That did nothing. I tried all kind of different settings and that did nothing. I called a repair place but they wanted 300.00 just to come and look at it.
i have the sony kds 50a2000. it keeps on overheating and shutting down. the fan that expells heat...
(More)
i have the sony kds 50a2000. it keeps on overheating and shutting down. the fan that expells heat from the bulb after about an hour it starts making a noise like its rubbing against something. approx 30 minutes after the tv shutoff but the fan still running.
i have the sony kds 50a2000. it keeps on over heating and shuts off. but the fan by the light that...
(More)
i have the sony kds 50a2000. it keeps on over heating and shuts off. but the fan by the light that expells the heat after about an hour makes a noise like its rubbing against something about 30mins after it shuts off.
